Decided to change my spark plugs today on my E89 2.3 2011 put in NGK Laser Platinum 5987 as recommended by Autodoc with preset gaps
Now it’s running like a bag of spanner’s with the engine warning light on
Spark plugs
Spark plugs
N52K engine six cylinderNewboy1946 wrote: ↑Thu Jul 28, 2022 7:55 pm Decided to change my spark plugs today on my E89 2.3 2011 put in NGK Laser Platinum 5987 as recommended by Autodoc with preset gaps
- Smartbear
Spark plugs
Double check you’ve reconnected the coils correctly, it’s probably something you’ve done but you may have a faulty plug.Newboy1946 wrote: ↑Thu Jul 28, 2022 7:56 pmN52K engine six cylinderNewboy1946 wrote: ↑Thu Jul 28, 2022 7:55 pm Decided to change my spark plugs today on my E89 2.3 2011 put in NGK Laser Platinum 5987 as recommended by Autodoc with preset gaps
I’ve recently changed a lambda sensor on our yeti with a Bosch oem replacement & it was faulty from new
e85 3.0si sold
- B21
Spark plugs
Smartbear wrote: ↑Thu Jul 28, 2022 8:04 pmDouble check you’ve reconnected the coils correctly, it’s probably something you’ve done but you may have a faulty plug.Newboy1946 wrote: ↑Thu Jul 28, 2022 7:56 pmN52K engine six cylinderNewboy1946 wrote: ↑Thu Jul 28, 2022 7:55 pm Decided to change my spark plugs today on my E89 2.3 2011 put in NGK Laser Platinum 5987 as recommended by Autodoc with preset gaps
Rob’s suggestions are good ones..
