Heated seats
- B21
Heated seats
Great write up…well done
Heated seats
I can't remember the IHK step either, and I think this may be because in the E9x series you can code the CIC to control heating functions (not possible in the Z4), so I'd assume this write is for the E9x. Saying that all the steps are correct, no harm in coding the IHK it will just take the coding without issue.
Dave
2011, 23i, Grey with Red leather.
- ProfCJJ
Heated seats
Thanks all. The text is an amalgam of 5 different sources - none of which specifically mentioned the E89 - I will leave the IHK steps out to see if that works. I'll adjust the text if so and will update my how-to I am working on.
- ProfCJJ
Heated seats
Progress of sorts.
My coding instructions did not set the car ablaze - a bonus(!) - and now the passenger has full heating on all three settings. For the drivers seat, the 3 LEDs come on when button is pressed, and decrease to 2 or 1 when re-pressed but only stay on for about 5 seconds ... I think I have read this somewhere before so going to have a quick read to see what is missing - if anyone knows please do shout!
Nearly there
Nearly there
Heated seats
Quite a bonus. and a massive step forward! I didn't have that problem, but hopefully a google will give you some suggestions. I was the other way around for about 3 months in terms of no heat from the passenger seat, until I worked out it needed the JCB coding...
https://www.e90post.com/forums/showthread.php?t=755275
a number of culprits on this thread.. hopefully not your elements and possibly the "usual suspect" (battery)! worth going out and charging your battery just in case?
Heated seats
Switch lights going off, I had this on my passenger side, it was the fuse. Drivers side should be fuse 46
Dave
- ProfCJJ
Heated seats
I use fuse 46 to power BOTH the passenger and driver’s seat - so as passenger seat heats up that sounds odd - might be something related though so will look at power to the seat and the under seat plug
I don’t think there is any coding left for me to do ?!?
- ProfCJJ
Heated seats
Well, Fuse 46 is intact, I had a quick try to reseat the connectors under the drivers seat, just in case its a dodgy connection issue - nothing. Rain stopped play, but if I can tomorrow I'll remove the driver's seat module and take a look there ...
Heated seats
How are you getting on. its annoying when its not something obvious (it took me about 3 months to get the passenger seat going).
Is it possible to check if the car sees the driver side module or not via INPA?
- ProfCJJ
Heated seats
Hi. I was at the NEC at the Classic Motor Show most of last week and so didn’t have any opportunity to take a look. This weekend I intend to start looking at connections and then see if I can see anything wrong via the diagnostics. I’ll keep you posted.
- ProfCJJ
Heated seats
I had time this weekend to hook up the computer to the E89 to query the seats/ seat modules.
I think I have a good lead and software works - as I can connect and query various ECUs and code things up ... yet when I try and query the seat modules (either drivers or passengers, it doesnt matter) as follows:
I get the following errors:
I don't think its due to a bad cable as I can do other things ... I wonder if I need to update my SP-DATEN files??
Bear in mind that the Passenger heated seat works fine - just not the driver's ... I will try and lift the seat and look at the module etc but with the rain peeing down it will have to be later this week.
Heated seats
You appear to be able to ask INPA what modules are installed from this link if it helps to see if it "thinks" it should be?
https://www.bimmerfest.com/threads/760l ... 687/page-2
I no longer have my laptop that was running inpa, so I cant test this myself now unfortunately.
Heated seats
I had a look in my foxwell setup, and my recent scan only shows the "seat module - driver SMFA" on my test result. I know when I did my previous install they are different types of modules so to me it looks like you wont be able to connect to the passenger seat one, and you really do have some sort of fault (cabling/hardware or software) on the drivers one, so they appear the same. Annoyingly now that I have upgraded to Windows 11, I don't seem to be able to make my laptop communicate with my Foxwell NT530 either !
- ProfCJJ
Heated seats
Thanks for looking into it. Yes, I assume the PWM method for the passenger seat is handled differently than the (heated) seat controller of the driver's side so the diagnostics could be misleading. I think I will only really get to the bottom of this if I pull the seat out, check cables and do some measurements - for that I need a half decent day!clarker63 wrote: ↑Mon Nov 21, 2022 5:11 pm I had a look in my foxwell setup, and my recent scan only shows the "seat module - driver SMFA" on my test result. I know when I did my previous install they are different types of modules so to me it looks like you wont be able to connect to the passenger seat one, and you really do have some sort of fault (cabling/hardware or software) on the drivers one, so they appear the same. Annoyingly now that I have upgraded to Windows 11, I don't seem to be able to make my laptop communicate with my Foxwell NT530 either !
Thanks again
