Heated seats
ProfCJJ
Heated seats
Post by ProfCJJ » Mon Nov 21, 2022 11:26 pm
It looks like I have 2016 (vers 61?) SP-DATEN files of E89 - which I assume is OK??
The info is pretty sketchy on this software isn't it??? :headbang:
Christopher
Z4 E89 sDrive 30i Msport in Alpine White with Kansas red leather interior and brushed aluminium carbon fibre look.
clarker63
Heated seats
Post by clarker63 » Tue Nov 22, 2022 1:43 pm
I checked my old installation but it was older than that - i've just downloaded the bmw tools from bimmergeeks and the sp-daten files are dated 2016. this is the file I believe tells you the version - is this the same as yours?
// Auftragsdatei: E89AT.000
// -350-
// Erstverw.Kogr.: 61.35
// Ident-Nummer: 6 933 698.5
DATUM 03.05.2016
I was able to communicate with the drivers side module (although it said there was a version mismatch, not sure if thats standard or not?) but nothing from the passenger side as expected.
ProfCJJ
Heated seats
Post by ProfCJJ » Tue Nov 22, 2022 2:05 pm
clarker63 wrote: Tue Nov 22, 2022 1:43 pm I checked my old installation but it was older than that - i've just downloaded the bmw tools from bimmergeeks and the sp-daten files are dated 2016. this is the file I believe tells you the version - is this the same as yours?
// -350-
DATUM 03.05.2016
Great, I have exactly the same version - thanks for checking.
It may well be I have an issue with the can bus at the drivers seat module (or the module itself of course).
I guess you accessed the module using the same route I showed above under “seat modules”?
Christopher
clarker63
Heated seats
Post by clarker63 » Tue Nov 22, 2022 2:11 pm
ProfCJJ wrote: Tue Nov 22, 2022 2:05 pm above under “seat modules”?
yes. mine looks exactly the same as yours. I did wonder if the "(new)" meant that it knew something had changed, but its the same as mine.
AnubisZed
Heated seats
Post by AnubisZed » Tue Nov 22, 2022 2:23 pm
Dave
2011, 23i, Grey with Red leather. 8)
clarker63
Heated seats
Post by clarker63 » Tue Nov 22, 2022 2:24 pm
cheers Dave! do you normally expect to see the "version incompatibility" type message ?
AnubisZed
Heated seats
Post by AnubisZed » Tue Nov 22, 2022 2:25 pm
A very good explanation on how to set it all up and update....
https://www.youtube.com/watch?v=lbM4XgAtWcI
Dave
AnubisZed
Heated seats
Post by AnubisZed » Tue Nov 22, 2022 2:28 pm
Version Mismatch message is always there, ignore it :thumbsup:
Dave
ProfCJJ
Heated seats
Post by ProfCJJ » Tue Nov 22, 2022 2:47 pm
Thanks Dave, much appreciated.
Christopher
