Help getting front top mounts
"M" Specific discussion
maddstaff
Post by maddstaff » Thu Jul 21, 2022 3:10 pm
Hi looking to buy new top mounts for my z4 m r, was wanting lemforder, but can’t find anywhere that sales them, please if anyone has a link cheers, or anothe make equal 2 these, bmw want £85 pound each
AndyBeech
Post by AndyBeech » Thu Jul 21, 2022 3:31 pm
You don’t need the whole top mount assembly unless it’s damaged which is highly unlikely. Just the bearing is fine, part number: 31331090612
It should only be around £20 each, I wouldn’t bother getting a different make even if it’s possible with that part, just go OE.
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
maddstaff
Post by maddstaff » Thu Jul 21, 2022 5:12 pm
AndyBeech wrote: Thu Jul 21, 2022 3:31 pm You don’t need the whole top mount assembly unless it’s damaged which is highly unlikely. Just the bearing is fine, part number: 31331090612
cheers is there not a rubber part to the mount as well that could need changing cheers
AndyBeech
Post by AndyBeech » Fri Jul 22, 2022 12:44 am
maddstaff wrote: Thu Jul 21, 2022 5:12 pm
No that part is the bearing, ie. the rubber part.
maddstaff
Post by maddstaff » Fri Jul 22, 2022 1:12 pm
cheers ive ordered 2x that part from bmw, and they have also sold me some spring part as well to go with this, still not half the price of two new mounts thou so thankyou
AndyBeech
Post by AndyBeech » Fri Jul 22, 2022 1:56 pm
maddstaff wrote: Fri Jul 22, 2022 1:12 pm cheers ive ordered 2x that part from bmw, and they have also sold me some spring part as well to go with this, still not half the price of two new mounts thou so thankyou
Probably the upper spring pad.
maupineda
Post by maupineda » Fri Jul 22, 2022 3:33 pm
Top mounts do wear, the rubber cracks. I would change them, they are not too expensive, but aren’t cheap either
AndyBeech
Post by AndyBeech » Fri Jul 22, 2022 4:01 pm
You mean this rubber bit?
Mine have 100k on them and are showing no wear at all? Rubber on those bits are hard as nails not the usual softer type rubber you find on the boots of the other suspension parts, no cracks on mine.
None of the specialists I went to recommended changing that part just the bearing.
IMO if you want to be perfect go for it, you won’t have much of a bank account left though if you replace everything you possibly can when you don’t need to on these cars. You can inspect it when your changing the suspension / changing the bearing if you want and if it looks damaged replace it, I would bet money on it being absolutely fine.
maupineda
Post by maupineda » Sat Jul 23, 2022 12:07 am
it can happen, see this. I changed them, but if the rubber looks good, you can reuse. I would change them though
https://www.e90post.com/forums/showthre ... p=19544730
AndyBeech
Post by AndyBeech » Sat Jul 23, 2022 1:32 am
maupineda wrote: Sat Jul 23, 2022 12:07 am it can happen, see this. I changed them, but if the rubber looks good, you can reuse. I would change them though
Different top mounts, not sure you can compare TBH. I've never heard of a Z4M (or E46 M3) have top mount issues in that department, I stand to be corrected though.
I mean you'll be looking at them anyway if your changing the suspension so look then. Have to agree to disagree on just changing them though, if it ain't broke....throwing money away IMO.
