Been going through some old post and N52 Water pump issues mentioned alot, kicking in
at around the 60K mark.
I am approaching 54K, should i start to be getting concerned and keeping an eye on it?
Did a search, does not throw up any real issues for E89's unless i have missed something.
20i - Build date April 2014
N20 Water pump
- N4LLY
- B21
N20 Water pump
Different , later design of engine…no evidence I saw of an endemic failure point…so I’d run it till it fails…and/or wait till 80k ish miles and do the thermostat and accessory belt at the same time…
N20 Water pump
I see this weather testing a few car cooling systems
The sound of fans running on.
- N4LLY
N20 Water pump
My car 96k miles, no cooling issues.
Can understand that hotter climates probably put a strain on plastic components.
Did notice air con pump is noisy though, noticed as i rarely use it.
N20 Water pump
That may have something to do with it.
Car a/c should be run for a good few minutes every month at least; keeps all the seals and internals lubricated.
Biggest cause of refrigerant leaks is lack of use.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- N4LLY
N20 Water pump
Out yesterday in the heat, roof down A/C on, was an absolute joy
