Its worth a check- I think when we replace the current expansion tank I'll run a hose through it too
Is fuse 61 in the engine bay? Cant see it on the fuse board
Thanks Paul- I tried to fire the fan using INPA and nothing- I am now leaning (once fuses are checked) toward the sensor being faulty!PDJ wrote: ↑Tue Jul 19, 2022 10:10 am So the rad fan in my car (an M car) the rad fan is off until either the air con is turned on and the fan runs at lets say 25% then as the temp increaces to the higher set point it then runs (lets asume) 100% it may control but other than puting the temp sensor in a controled temp I can not prove it. the fan runs unlit the temp drops to the lower set point.
I can activate the fan with my code reader to run at full speed and turn the air con on to test the lower speed.
The way mine is wired is there are 2 big wires that are live and negative feed that are live all the time (ign on) there is a 3rd wire that is the feed to the controler this apears to come via the temp sensor with is a NTC type of sensor so it is a 12v in and a veriable volts out to drive the fan controler
My 1 serries has 2 signal wires going to the fan controller and the two big wires
The temp sensor looks to fit almost every BMW they have made looking at realoem
picture of sensor and wiring diagram showing the NTC detail.
Seeing this one- not on the main fuse board though
Ah
Never thought to look that far up tbh.
I love a clever check
Same here, but always good to see something new that is specific to these cars.
