Hi there.
My 2005 E85 has a squeal that only develops once the engine is warm.
On idle, it’s barely noticeable, but as as soon as the clutch is raised, and any amount of transmission is engaged, the squeal gets much louder. When manoeuvring at low speeds it’s very prominent.
It sounds like a belt, but it’s making me question what it is because of how it reacts. But I also don’t know what I’m talking about.
Any thoughts on what to check?
Thanks.
Squeal when warm
Squeal when warm
Check the bearings in the alternator, pulleys and tensioners. I normally to take a peice of hose and sick it in my ear then use that to try and locate sounds. Obviously don't put it anywhere near the belts or anything else that's moving under the bonnet.
Onlinebigwinn
Squeal when warm
Oil filter would be my guess
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- BumpyZ4
Squeal when warm
Does it only happen when you turn the steering wheel?
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
- BumpyZ4
Squeal when warm
Then I would agree with bigwinn it's most likely a collapsed oil filter.
KLR 650
KLR 650
Squeal when warm
Finally got around to replacing the oil filter and sadly that hasn’t made a difference.
Still only when warm and goes away entirely when the clutch is engaged regardless of road speed.
I’m stumped.
I’m stumped.
Onlinebigwinn
Squeal when warm
Can you capture a video of it?
EWS Delete PM me
EWS Delete PM me
