That's interesting. The one I did was a pre-facelift so maybe there's the difference?
SOLD E85 2.2 2004 BREAKER ***GONE***
- enuff_zed
E85 2.2 2004 BREAKER ***FINAL KNOCKINGS***
Yeah I think with the pre FL, they put a lot more wiring in
18 Z4s owned to date.
Current: 2.5i Titan silver
- enuff_zed
- ryushe
Mine is a pre FL car so hopefully should 'just work', but good to know.
Seeing as the '03 and '04 cars basically are prewired for most options (or so I understand), can't imagine it being a big issue.
Will report back when it's here and hopefully fitted!
'06 E85 Z4 3.0si 6 speed manual - Black metallic w/ champagne interior
Prev BMWs: '04 E85 Z4 Individual 2.5i • '04 E85 Z4 3.0i • '04 E46 M3 • '04 E61 535d • '86 E28 525i • '87 E28 528e
- bigwinn
I retrofitted to an 05 car and although the map lights didn’t work the other main light did
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- enuff_zed
I find that a little odd tbh? Not doubting you, just that when you look at the back of the light it 'appears' to be a simple supply ring to them all, with on/off switches.
- bigwinn
its gone
But lots of bits left so PM me if you want anything specific
Stuart
Stuart
EWS Delete PM me
EWS Delete PM me
- enuff_zed
Can I have my wheels back? Changed my mind.
- bigwinn
Ah
You could bank on them coming back as the next toaster you buy?
EWS Delete PM me
EWS Delete PM me
- ryushe
Late reply, but got it fitted in the car. Connector is the exact same, and the hardware fit right in. Not that I expected it not to.enuff_zed wrote: ↑Sun Jul 17, 2022 1:50 pmI find that a little odd tbh? Not doubting you, just that when you look at the back of the light it 'appears' to be a simple supply ring to them all, with on/off switches.
That being said, I also only have the main light work, the maps lights do nothing. Will pull it out again soonish and investigate, as I think I can simply rewire the thing so that the map light switches work on the same circuit as the main light.
But interesting none the less that they don't work...
- enuff_zed
OK, here's a random thought. Maybe they only work when the ignition is on? So a passenger can navigate while you drive?ryushe wrote: ↑Sat Aug 13, 2022 5:15 pmLate reply, but got it fitted in the car. Connector is the exact same, and the hardware fit right in. Not that I expected it not to.
- ryushe
Yeah tried that, no dice sadly. Shouldn't be too hard to modify and loop it in to main light's circuit.enuff_zed wrote: ↑Sat Aug 13, 2022 5:24 pmOK, here's a random thought. Maybe they only work when the ignition is on? So a passenger can navigate while you drive?ryushe wrote: ↑Sat Aug 13, 2022 5:15 pmLate reply, but got it fitted in the car. Connector is the exact same, and the hardware fit right in. Not that I expected it not to.
Do you still have the hedgehog resistor? I'll take it if you do!
- enuff_zed
If he hasn't then I have one, but be polite and let bigwinn reply to you first, as per forum decorum.
- bigwinn
Sold today-
EWS Delete PM me
EWS Delete PM me
