Hi all. I have a problem with the diff. The noise is getting worse.
Is there any suggestions on how to reduce this noise apart from replacing it.
Many thanks in advance.
Differential noisy
Differential noisy
How do you know it's the diff? I take it you changed the fluid?
- enuff_zed
Differential noisy
If it is definitely the diff and it is getting worse then I'm afraid you just have the one option.
I had a friend with an old Cortina many years ago who decided to just turn the radio up.
On a busy roundabout it seized and helped him wipe out three other cars and give at least two people whiplash injuries.
- mkinternet
Differential noisy
Hi
I had mine serviced by these guys - https://www.acegearboxes.co.uk/. Two years on and its as quiet as a mouse, no whine, noise or leaks. Cannot receommend these guys enough.
Steve
Steve
E89 - 3.0i Auto 2010
Bilstein B12 Pro Kit
Wiechers Front Strut Brace
19” MAK LUFT Wheels
H&R Anti Roll Bars (Front and Rear)
Royals Steering Wheel
35i Brake Upgrade
Stage 1 Remap
19” MAK LUFT Wheels
35i Brake Upgrade
Stage 1 Remap
Differential noisy
Problem is that buying a used diff could put you back in a similar situation soon after. If its noisy, then no amount of oil changes will fix this. I suspect a refurbished diff is possible. Most gearbox places , I am sure, can source bearings and seals and will start again with a clean internals and fresh oil.
E86 In sapphire black
