No alarm arming or flashing indicators
Reamesy
Post by Reamesy » Thu Jul 28, 2022 11:38 pm
mr.tourette wrote: ↑Tue Jun 28, 2022 2:43 pm If the door cards have ever been off a wire may have been damaged, the wiring on the modules inside the door card look extremely delicate around 1mm thick and I can see how they would be easily damaged if you are not extremely careful with removal
You may actually be on to something. ISTA could not communicate with the alarm module on Terminal 15. I found the fuse 7.5amp was blown.
Replaced it and the clown nose now flashes when locked and behaves normally. However the interior is not being monitored. If I lock the car with the roof down or window open nothing will trigger the alarm. However if I jack the car the tilt switch kicks in!
Door skins off is my next job to check the DWA modules.
I will update as I go.
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Reamesy
Post by Reamesy » Fri Aug 19, 2022 2:22 pm
So finally got to do some more digging into my alarm. The only thing not working was the microwave sensors.
So took the door cards off. Passenger side all good.
Drivers side someone had been in there and pulled the wires out of the connector. That would explain the blown fuse.
Re pinned the connection and replaced the fuse again (as it blew when I touched the wires).
And….all working perfectly πŸ˜ŽπŸ‘
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
B21
Post by B21 » Fri Aug 19, 2022 2:41 pm
Like it when people report back..very irrating when advice is given and you never hear back.. :thumbsup:
A very modified Atacama Yellow 35is :thumbsup:
Reamesy
Post by Reamesy » Fri Aug 19, 2022 2:49 pm
You were right all along. Great advice. Thank youπŸ˜ŽπŸ‘
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
mr.tourette
Post by mr.tourette » Fri Aug 19, 2022 4:58 pm
Reamesy wrote: ↑Fri Aug 19, 2022 2:49 pm
No worries buddy, glad you have it sorted :thumbsup:
