Recently I've been having a minor issue with my windscreen washer. When I pull (and hold) the stalk to wash there is about a 2-3 second delay where you can hear the pump but no water is coming out the jets. When it does eventually spray there is no issue with the spray/pressure. The washer bottle is also full, so not an issue with empty bottle. I thought it could be a clogged filter, but surely the spray would be a dribble if that was the case?
Let me know if any of you guys have had this issue before?
Windscreen washer delay
- TheDan
Possibly the pipe has a minor leak?
As in it drains a bit when not in use and the next time you use it needs to fill up again before spray reaches the nozzles.
- enuff_zed
As above, but it could also be debris settling that the pump has to shift first.
Definitely clean the filters too.
- TheDan
Thanks both. I'll take the reservoir out, clean the filters, remove the pipes and check them. Not actually taken the reservoir off on the Z4 before, is it pretty easy to do? Do you know if there are any write ups/images anywhere on forum?
- enuff_zed
Dead easy.
One bolt at the top.
You will need to wriggle the connectors around and the hoses.
I try to pull the pumps out but leave everything connected to them. Little bit fiddly but no great problems really.
Other thing I thought of................. is there a non-return valve in the line somewhere to stop it draining back? Maybe that has a bit of crud holding it open (if there is one?)
Well they didn't think to put one in below the level of the tank... but that doesn't mean a different team didn't over-engineer the lines above
