Hidden lights
- Johnbmwz4
Hidden lights
I never knew there were lights here is this standard or part of lights package?
BMW E89 3.5i M Sport manual, loving it….
Audi S5 Cab, Great car but not special enough….
BMW E89 3.5i DCT, Havana Brown, should never have sold it…..
BMW E85 3.0 Auto, sadly missed (twice)
- B21
Hidden lights
Extended lighting package I believe..
Hidden lights
Mine's got them. Not sure what the red light's for?
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
- Marcoose
Hidden lights
Clown detector. Never fails.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
- N4LLY
Hidden lights
Where are they hidden ?
- Johnbmwz4
Hidden lights
At each side behind the seats
Hidden lights
What are the red lights for then?
2000 Z3 3.0
2000 Z3 3.0
- B21
Hidden lights
SV8Predator wrote: ↑Mon Jun 20, 2022 9:43 pmWhat are the red lights for then?
Chromatic aberration
- N4LLY
Hidden lights
Hhhmmm mine are different
Hidden storage, found recently
- 20220621_112636.jpg (101.08 KiB) Viewed 652 times
- B21
Hidden lights
They are the same extended lighting package..you have the extended storage option as well…
The red light is chromatic aberration..the bright white light is reflecting internally within the camera lens system creating an artefact …often referred to as lens flare..example in an expensive camera here..
- C135AD80-176F-48F6-9E44-1A6CC0943252.jpeg (89.51 KiB) Viewed 639 times
- N4LLY
Hidden lights
Ah ! Righto driverB21 wrote: ↑Tue Jun 21, 2022 12:17 pm They are the same extended lighting package..you have the extended storage option as well…
- Johnbmwz4
Hidden lights
Just noticed the red light only stays on for around 10 seconds but the white light stays on. When I now open the door only the white light comes on no red light, same when I lock and unlock the car. I wonder if the car has to be locked for a while then unlocked before the red light works?
- Ole gits rule
Hidden lights
Just checked mine, they are located where Johns are and only the white light comes on but there is a second hole above which could be for a red light.
In all honesty, when the seats are back they are pretty useless where they are
M4 Vert in Yas Marina Blue
- N4LLY
Hidden lights
Now confused Where is this mystery red light ?Johnbmwz4 wrote: ↑Tue Jun 21, 2022 9:20 pm Just noticed the red light only stays on for around 10 seconds but the white light stays on. When I now open the door only the white light comes on no red light, same when I lock and unlock the car. I wonder if the car has to be locked for a while then unlocked before the red light works?
- Marcoose
Hidden lights
Resident clown to the white courtesy phone, please. Or the red one.
