Map update Europe 2022-2
Discussing the current generation Z4
q96169we
Post by q96169we » Fri Jul 01, 2022 2:21 pm
Schaef wrote: Thu Jun 30, 2022 1:55 pm And then press 3 times the startbutton to put the car in service stand. Maybe that’s the problem for not working.
Triple press start button is not necessary for the car to initiate the update process. As long as the idrive is on, plug in usb stick with map should trigger the update. In theory, this should be the case but obviously, there are many other factors that may lead to update not being triggered.
Triple press start button will put the car into diagnosis mode whose purpose is simply to keep the car on for the entire duration of the update if you don't want to start the engine.
q96169we
Post by q96169we » Fri Jul 01, 2022 2:35 pm
Nanu, glad it works for you now. It's always tricky to figure out the compatible issue around usb memory stick.
Schaef
Post by Schaef » Fri Jul 01, 2022 3:36 pm
q96169we wrote: Fri Jul 01, 2022 2:21 pm
Oké that i did not know.
Argyll Andy
Post by Argyll Andy » Fri Jul 01, 2022 3:43 pm
Just done that just now. First chance I’ve had to get the roof down so I can lean in to press the button. Put the usb in before triple press, as soon as I did the presses it came up with map update confirm, pressed confirm and it’s uploading as I type :thumbsup:
    E89 23i sDrive, Silver (Gone)
    q96169we
    Post by q96169we » Mon Sep 12, 2022 5:02 pm
    2022-3 map is available now.
    speedin70
    Post by speedin70 » Tue Sep 13, 2022 2:26 am
    Nice map, looks like a video game when you discover part of the map! 🧐 Am I right saying you drew the capitals with a star? If so, you should correct Switzerland, and put the star in Bern not Zurich. 😉
    https://routerlogin.ltd/
    https://pikashow.ltd/
    ori
    Post by ori » Wed Sep 14, 2022 7:54 pm
    I’ll update as soon as my car comes back from Bodyshop getting a new bumper. Might download it ready for collection. ;)
    Still no sign of a general software update.
    Scubaregs
    Post by Scubaregs » Wed Sep 14, 2022 8:20 pm
    Having problems again, it downloads and validates, but then gives an error when saving. Shows on my removable disc but does nothing in car.
    Image Image
    ori
    Post by ori » Thu Sep 15, 2022 6:10 am
    If it shows an error when saving to the usb stick, then obviously there will be a problem in the car.
    How much space on your usb stick? And what format is it? Have you cleared it before doing the update?
    Scubaregs
    Post by Scubaregs » Thu Sep 15, 2022 6:42 am
    500GB, EX FAT, cleared before use.
    Had the same issue with another memory card.
    Image Image
    q96169we
    Post by q96169we » Thu Sep 15, 2022 9:32 am
    500GB sounds like a portable HDD instead of Flash stick. The HDD may require more power than the car can supply unless it's USB-C. I think ori tested before about the USB-C functionality and his result showed that the USB-C can be used to update map as well.
    Scubaregs
    Post by Scubaregs » Thu Sep 15, 2022 1:27 pm
    A 64 GB memory card had the exact same result. Downloads, validates, errors on saving.
    Image Image
    q96169we
    Post by q96169we » Thu Sep 15, 2022 2:01 pm
    When you say errors on saving, do you mean the BMW Download Manager on your computer instead of the car throws the errors when it tried to save the data to the usb stick?
    Scubaregs
    Post by Scubaregs » Thu Sep 15, 2022 3:29 pm
    Downloads using download manager, verifies using download manager. (All onto removable storage) Once verified and I click save, then I get an error.
    Image Image
    Roadster_Surrey
    Post by Roadster_Surrey » Thu Sep 15, 2022 4:34 pm
    Worked for me ok. Applied update today. Good timing, as I decided on last minute euro-trip.
