Hei
Kjøpt oss en Z4 35i 2009mod
ved åpning av tak stopper sekvensen nesten med en gang bakruta begynner å løfte seg 5cm, da stopper det. Feilsøkt på BMW å de sier at det er ledningsbrudd.
Har bestilt time 10/6 men etter å ha prøvd taket i dag igjen (samme skjedde) vil heller ikke vinduene gå igjen og får nå heller ikke åpnet koffertlokket.
Er det noen tips om å resette vindusfunksjonen.
Magnar
taket vil ikke ned
- Smartbear
taket vil ikke ned
Hi Magnar, this is an English speaking forum so don’t think you’re going to get much response with your post
e85 3.0si sold
taket vil ikke ned
Norwegian to English
Bought us a Z4 35i 2009mod
when opening the roof, the sequence stops almost as soon as the rear window starts to lift 5cm, then it stops. Troubleshooting on BMW to they say that there is a wire break.
Have booked hour 10/6 but after trying the roof today again (same happened) the windows will not go again and now I can not open the boot lid.
Are there any tips on resetting the window function?
- enuff_zed
taket vil ikke ned
Hi Magnar
Welcome to the forum.
The very best thing you can do is look for posts by RobbiZ4 who is an expert on the E89 roof.
Good luck.
Good luck.
taket vil ikke ned
when opening the roof stopper sequences almost immediately the rear window begins to lift 5cm, then it stops. Troubleshooting on BMW to they say that there is a wire break.
Have booked time 10/6 but after trying the roof today again (same happened) the windows will not go again and now I can not open the boot lid.
Are there any tips on restoring the window function.
- Smartbear
taket vil ikke ned
It sounds very similar to this viewtopic.php?p=1929935&hilit=Phoenixboy#p1929935Magnar wrote: ↑Sat Jun 04, 2022 8:24 pm Bought us a Z4 35i 2009mod
Good luck
e85 3.0si sold
