Is there a way to tell what speaker set up the E89 has without a spec check?
- hopz121
Hi all,
Looking to change my daily with either an E85/86 or an E89 and have some questions regarding the speaker upgrades from factory.
With the E85/E86 a tell tell sign was the subs behind the seats told you it had an upgrade followed by the dsp settings on the headunit to distinguish if it was the mid level or top level.
I have limited knowledge of the E89 platform, is it similar to the E85/E86 with subs behind the seats or cubby holes or is it not that simple?
Any help would be appreciated, most sellers won’t know what speaker set up there car has so an easy way for me to find out would be great.
Additionally did the I drive headunit come with a speaker upgrade from factory? Is DAB an option as well?
Ash
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
OnlineArgyll Andy
Hi Ash from my recollection basic has no speakers behind the seats, mid range has two behind the seats and top has two behind the seats but also one in the middle above the cubby hole between the seats.
Re the iDrive, no having an iDrive does not mean upgraded stereo/speakers, they were two separate options and often not ticked together
Someone may be along to give a much more detail explanation but that’s at least a starter
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
There is a diagram on a recent thread, by B21 I think, which shows the differences in the optional speaker upgrades. Try searching for 'speaker upgrade' and look for threads by B21.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
OnlineArgyll Andy
Visually, with just the ones in the yellow squares, mid (11 speakers system) additional red square, top (14 speaker system) nothing behind the seats, base system
As Pondrew said Peter gave a detailed post about the systems and functionality
- D83D542D-90E6-4D93-83EF-2CAC0C76707B.jpeg (79.51 KiB) Viewed 422 times
- B21
The 6 speaker system has lettering on the radio unit, the others don't
The 6 speaker system doesn't have tweeters in the plastic pods on the doors at their leading edge (you can see the silver of the tweeter glint if you peer through the mesh) and no sub-woofer grills behind the seats, 4 channels driving 6 speakers
If you have subwoofer grills and tweeters glinting at you then you probably have the 676 Hi-Fi system with 7 channels driving 11 speakers
The 14 speaker system is quite rare..the easiest way to work it out is to go to the tone menu and see if there is a graphic equaliser option, that only appeared on the 677 Top-Fi system with 10 channels driving 14 speakers
- BMWZ4E89Speakers_zps399c634b.gif (84.28 KiB) Viewed 389 times
- hopz121
Thanks for the replies guys this is very helpful.
Similar to the E85/E86 platform then, if you have speaker grills behind the seats hen you have a hifi upgrade of some sort.
is the dash grill in all cars regardless (with or without a speaker behind) or only with a hifi upgrade? Trying to work out an easy way to spot this in classified photos
- B21
Dash grill is present in all versions (AFAIK)..the rear centre grill between the seats is only there on the 677 option.hopz121 wrote: ↑Thu May 26, 2022 4:06 pm Thanks for the replies guys this is very helpful.
- davegt
Mine must be a strange set up then, I have the basic 6 speakers plus the door pillar tweeters - yes they are fitted an functional Which reminds me that i need to get my sub fitted at some point...
Daily: 2022 Mercedes GLB mileage muncher
Weekend: 2010 E89 35i, Stubby, Black Grills, Milltek exhaust, DCI, Carplay, BC Coilovers, Black Aluwerk 19" Alloys. (Parts sat collecting dust: IS diffuser, m4 carbon spoiler, FMIC)
- mr.tourette
Probably somebody has just upgraded them..I've done it in mine..big improvement too
- B21
By now quite a few cars have had their audio systems twiddled with..often using a scan tool like Bimergeeks Protool shows up 'irregularities' in the audio systems which is an indicator of twiddleness..mr.tourette wrote: ↑Fri May 27, 2022 11:44 amProbably somebody has just upgraded them..I've done it in mine..big improvement too
if you go to https://www.bimmer-tech.net/ and type in your vin it will show you what stereo speakers you have already installed and any options you can do.
don't forget you can also change the factory equalizer settings in the menu
- B21
Which menu is that pls?
