Hey, it was late
All the lights and issues
I'm in Chigwell so that's about 50 mins from you. Maybe someone closer?
It does sound like a bad ground somewhere. I'd recommend picking up a multimeter and checking battery voltage when running and then checking ground points + fuses too.
EDIT. I'd also check on Binmerforums and E90 forums. There should be someone close to you that can read out codes.
