All the lights and issues
I have a 2007 Z4 roadster 2.5 si . Recently had problems with battery dying , I replaced for a new Bosch battery and this died overnight . Once the new battery was in all the warning lights are on. The speedo doesn’t work but the rev gauage does.the music system works and so does the roof .however no power steering , no abs and no traction control .all the lights are on. I’m terrible at knowing what to do or where to start and need to save some money and want to try do this myself however not many tools or knowledge .any advise ?or am I best biting the bullet and going to a garage
Your location?
Someone local to you with a code scanner my help
These cars are voltage sensertive
Have you tied to jump start it?
- colb
You really need to start by code reading the car with a decent scanner to see what fault codes have been set. Once you have the codes that will give some clues on where to start looking for whats wrong with it.
Handheld scanner like a Creator 310+ is pretty good and around £50 on ebay and amazon.
If you have a laptop then consider BMCables package that gives you BMW INPA diagnostics and NCS Expert for coding plus some other software for use with BMW's. Available on ebay comes with the interface for plugging in to the 16pin OBD2 port on the car and the laptop.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- Roberltd2
If you don't feel confident with using a scanner yourself, make enquiries to see if there's a good local independent garage nearby. Perhaps they could do a diagnostic check for a reasonable price (or free if you're lucky) and then take it from there.
2007 E85 2.5 si Sport in Montego Blue.
1994 Eunos J2Ltd - sold and now undergoing restoration.
1963 Triumph Thunderbird.
- colb
Update your user details and show where you are based so it appears on the left of your posts, add the model and year of your car as well. Could also put the details in a signature so it shows on your posts. It helps to know just in case someone is nearby to lend a hand with diagnostics etc.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
Before you do anything else make sure the cables are properly and tightly connected to the battery terminals. Tighten the nuts with a 10mm socket or spanner.
2003 Maldives Blue 3.0i auto
Peterborough ,Cambridgeshire . I don’t have a code reader .a garage replaced the battery . They said there’s loads of fault codes but they can’t be cleared and it’s showing as there’s no power to anything
BMW 2007 roadster - 2.5 si model
- colb
Hopefully a member in your area will have a scanner or other diagnostics to scan your car, until that can be done its all guesswork and its no good just throwing parts at the car in the hope it fixes things.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
Ok thank you , il try put a photo up later
Got a multimeter? Check that the battery is receiving 14v when the engine is running
E85 3.0
No I don’t have anything at all think I’ll
Have to bite the bullet and try take it somewhere ££££
- jimbo1958
If you have any aftermarket devices fitted I'd try disconnecting them first .
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
I do have an after market like cd music system but I’ve had it in 4 years with no issue .i should still try disconnect it ? Do I do that by simply removing the power cable from behind
Where are you based? Someone close to you may be able to at least read out your codes.
- N4LLY
" Peterborough ,Cambridgeshire . I don’t have a code reader "
