Long answer and picture heavy, apologise…
Took some photos and while there, measured the upper drain holes - they are actually bigger than previously reported, could easily fit a 11 mm probe in them. The hose beneath the drain hole felt rubbery and ribbed to the probe, so would definitely avoid any sharp objects.
First, how to visualise the drain holes. I have the roof motor relocation done and the left one can be inspected with minimal effort:
- 09BC0E86-EAE7-46D8-B1C7-8BFE40060502.jpeg (190.96 KiB) Viewed 342 times
- CB941240-28E1-46D1-8D9B-75138D494E97.jpeg (143.24 KiB) Viewed 342 times
- 63C8ED75-D9A4-451B-849B-BE7058291CF8.jpeg (126.71 KiB) Viewed 342 times
And the right one is the same:
- 0F0C4758-AA87-4C5F-A766-383DF39B6657.jpeg (146.93 KiB) Viewed 342 times
- F52FBCD4-BADD-4B3F-B064-DA1E587F7E77.jpeg (101.69 KiB) Viewed 342 times
- 3A9DA4C0-5883-4325-A900-71B26ECD4476.jpeg (121.91 KiB) Viewed 342 times
My weapon of choice keeping the wells clean from debris, a 13 mm silicone hose attached to a vacuum cleaner:
- 93511BA9-109E-417F-BCDF-0ABF01554F06.jpeg (121.86 KiB) Viewed 342 times
Would the well would be filled with water (never had that), I’d probably just shove a 10mm pin/probe or fluid extractor hose straight down the area marked on the first photo and poke the drain hole area free. If the roof motor hasn’t been relocated it’s a different story. The motor casing obscures the drain hole area and pressure air from above or via the lower drain exit might do the job.
