Hi, Really appreciate your comments.SonnyA85 wrote: ↑Wed May 11, 2022 9:21 am It's possible the new battery had been sitting on the shelf a while. He has then plugged it into his car and then not used it much. Forgot to charge it for a few weeks and now it's knackered. It's a possibility. I know this from experience. The charger I use is a ring smart charger with a lot more functions than the one he has. Because my neighbor had the same issue and I had to use my charger to show him the new true capacity of his battery even though his charger was saying it was fully charged. It was holding 10% of the original capacity. He needs to measure the capacity of his new battery and see if it's the battery or not. It's simple to then exclude that from the list of possibilities.
Mine has a reconditioning/repair function. I tried this several times on my old battery that I got a few years back and nothing. It would charge but capacity was gone. Showed the correct voltage but not enough crank in it to start the car.
I'm in his same shoes. It's why I now charge mine every weekend. Doing it once in a blue moon wasn't enough to save the battery. Every time it gets discharged it's killing his battery he's saying this has happened several times on his new battery so it's possible if he's got a parasitic drain the new battery has now been severely limited because of it.
Also when I got a new battery I tested it's capacity and it was higher than on the spec sheet. Spec said 780ah and I'm sure it was 820ah if I recall correctly upon testing. I would do this test when fully charged and see what happens.
He said he's already pulled all the fuses. I'm guessing the battery is knackered from the several times it's been drained and re charged. It's a possibility.
Get it on a decent charger and check how much capacity is left in it. The voltage it reads doesn't tell you anything you need to know how much ah it holds when full.
If the new battery is okay then I would look elsewhere for issues. I knackered a new battery by being a low miler. Top of the range Bosch it was too. I do have a £600 aftermarket amp in the boot so my car is power hungry. It's why I top it up every week. It's a pain but has to be done. I left it for 2 weeks and it had dropped to 80%. So it's losing 10% a week just sitting on the drive. If it goes below 60% you are in trouble as that's what impacts long term life.
I have just tested the battery (680 amp CCA) which I removed from the car (not yet replaced) and fully charged a few days ago. The readings appear good: Health 100%, Charge 98%, 765 CCA, 13.03v, Internal ressitance 3.91 ohms. Compared when I first purchased this new battery the readings were: Health 100%, Charge 98%, 750 CCA, 12.63v, Internal ressitance 4.00 ohms.
Recntly however, the battery had discharged signficantly (while in the car and connected), Health & Charge down to 6% and 0% respoectively, 170CCA, 9.49v and Internal ressitance at 17.48 ohms.
From what you say this 6-week old battery could be past it. But, I'm surprised the apparent health etc on testing appears to have held up after several days from when it was charged.
Derek
