Speaker upgrade
Speaker upgrade
Also has anyone replaced their speakers with the Bimmertech Alpha One set up?
Speaker upgrade
I just bit the bullet and went for the Vibe speaker & amp upgrade @ £264.58 delivered to Dublin with Prime.AnubisZed wrote: ↑Mon Apr 25, 2022 6:08 pm ... or if you just want the doors replaced, and you have Amazon Prime, then you could go for these Vibe midrange/tweeter package... https://www.amazon.co.uk/VIBE-OPTISOUND ... 189&sr=8-1
Vibe also make a plug-n-play amplifier that plugs into your existing speaker output which saves any re-wiring... https://www.amazon.co.uk/dp/B08FBHY5QG/ ... _lig_dp_it
Should have the amp delivered on Sat and the speakers on Sunday.
If possible, i will test how the Vibe Amp sounds with the stock BMW basic speaker setup then install the Vibe speakers on Sunday.
Speaker upgrade
Cheers I will have a look and let me know how it goes.
Speaker upgrade
If one does not have the mid-range speaker & tweeter at the front on the dashboard and in the back behind the center console is this difficult to get working?
i.e. Is there cabling already so that it will be a "plug & play" install or is there extra wiring involved?
- B21
Speaker upgrade
AFAIK the wiring harness for each car is specific to the sound system..it certainly is as far as the 676 vs 677 systems..wanderer wrote: ↑Thu Jun 09, 2022 10:08 pm If one does not have the mid-range speaker & tweeter at the front on the dashboard and in the back behind the center console is this difficult to get working?
Speaker upgrade
Hmm... That's as i suspected.B21 wrote: ↑Thu Jun 09, 2022 10:44 pmAFAIK the wiring harness for each car is specific to the sound system..it certainly is as far as the 676 vs 677 systems..wanderer wrote: ↑Thu Jun 09, 2022 10:08 pm If one does not have the mid-range speaker & tweeter at the front on the dashboard and in the back behind the center console is this difficult to get working?
Thanks B21!
Speaker upgrade
Vibe OptiSound AMP is in.
There is a huge amount of cabling that is not required. Vibe could have optimised this.
It does take quite a bit of space.
I have to figure this out as the head unit does not fit.
There is an improvement in sound quality.
Nothing major / stupendous. You wouldn't notice it if you didn't do a before & after. But considering the price, it's probably worth it.
Speaker upgrade
Amazon delivery this Sunday morning.
Speaker upgrade
Has anyone installed speakers and new wiring harness or is it just too bigger job, sometimes there’s a smaller link harness plugged into the main cabin harness?wanderer wrote: ↑Fri Jun 10, 2022 12:04 amHmm... That's as i suspected.B21 wrote: ↑Thu Jun 09, 2022 10:44 pmAFAIK the wiring harness for each car is specific to the sound system..it certainly is as far as the 676 vs 677 systems..wanderer wrote: ↑Thu Jun 09, 2022 10:08 pm If one does not have the mid-range speaker & tweeter at the front on the dashboard and in the back behind the center console is this difficult to get working?
Thanks B21!
- B21
Speaker upgrade
There is a big difference between all 3 audio systems..the basic system has no external amplifier..the other two have amps on the rear bulkhead…..the mid range amp uses analogue signal cabling the top end amp uses fibre optic…there may be some common wiring but it’s not that obvious..
Speaker upgrade
OK. So I purchased two sets of the Vibe OptiSound 4's for BMW.
Went to install one set on the rear mid-ranges only to find that they are too large.
Simply won't fit.
Are those speakers smaller than the door speakers?
Would like to know before I go removing the door cards.
Simply won't fit.
Speaker upgrade
Anyway, I have a spare set of brand new door speakers & tweeters if anyone is interested.
I will be in Stevenage over the weekend so I I can bring them over.
- mr.tourette
Speaker upgrade
The speakers in the rear are the same size as in the doors.. possibly the depth might be an issue though, not sure what the max depth is on the rears
Speaker upgrade
So where were you thinking of putting it?wanderer wrote: ↑Sun Jun 12, 2022 11:34 am Vibe OptiSound AMP is in.
A couple of suggestions...
1) On top of the glovebox.
2) On the bulkhead in the boot (same place as OE amp, if there is enough cable to do this).
How long is the cable loom?
Dave
2011, 23i, Grey with Red leather.
