Sport button mod
Sport button mod
Hi guys,as in the title I’m retro fitting the sports button to my 04 so was searching for white connector and I found this red one also,what’s it for?
- image.jpg (123.07 KiB) Viewed 927 times
- buzyg
- enuff_zed
Sport button mod
A random guess, but could one or two of those be pre-wired for an auto box?
Sport button mod
Auto box possibly,some knowledgeable person will let us know hopefully.Going in now I’ve watched a few YouTube videos on removing centre console and nothing broken yet
- image.jpg (152.33 KiB) Viewed 900 times
Sport button mod
It’s the (upright) rear console and compartment door you have to be very careful of. If you break some but not all of the trim clips, it’s not the end of the world but it will really p*ss you off.
2003 Maldives Blue 3.0i auto
Sport button mod
Getting this bit off was bad enough doing rear section now
- F4ECAA9B-1F68-4E45-8247-26EFB653E50B.jpeg (129.54 KiB) Viewed 878 times
Sport button mod
So far so good nothing broken
- 11C32811-B60D-4A3F-9DC9-085BAC59F6FE.jpeg (148.55 KiB) Viewed 863 times
- EFC34C3A-CD4D-41E3-A72F-F223D3944F93.jpeg (160.96 KiB) Viewed 863 times
- E072F723-F3F7-45CB-AF95-C8349E3F6927.jpeg (157.73 KiB) Viewed 863 times
- buzyg
- enuff_zed
Sport button mod
Would have been simpler to stick a false button on and buy some clogs!
Sport button mod
Dusty shoes modifying my garage door for the zconsole drilled out and plastic trim just crumbled think it was broken already and a good opportunity to fix broken white cord
- 0CC86ACB-A14A-45DC-9BA4-4BC5E6CC8FC0.jpeg (193.06 KiB) Viewed 846 times
- F787B550-309C-456E-B80B-918D04DFB3C5.jpeg (188.49 KiB) Viewed 846 times
- F2080E6E-54C2-45C9-B074-C036969D6163.jpeg (202.78 KiB) Viewed 846 times
Sport button mod
Broken bits
- F5DE0ACE-4080-45F2-8F5B-40CAD3CD9AAC.jpeg (160.96 KiB) Viewed 843 times
- 7CDCCE20-08D9-4D35-92B3-65858BBBE8D0.jpeg (216.01 KiB) Viewed 843 times
- kis
Sport button mod
Well, one plug is for the sports button, there is another one for the airbag deactivation, not sure which ones. So thats two. Interested to know what the others are too!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
OnlineScubaregs
Sport button mod
Easiest way to find out is to connect one of your choosing, select sport and accelerate into a wall. If the airbag fails to deploy you have not plugged into the sport button connector.
- DMike
Sport button mod
Hi Robster68,
The switch (S13772) plugs into connector X13778, which should have pin 1 brown & black, pin 2 grey & red, pin 3 black & grey & yellow, pin 4 green & blue & yellow, pin 5 black & red & yellow. Hope this helps.
2005 Z4 3.0i Sterling grey
