Bimmercode ??
Bimmercode ??
Just looking into getting the bimmercode app, to do some coding on my new steed.
Sound upgrade etc etc...
I use an android phone.
Ive looked at the bimmercode site , and there seems to be lot of interface adapters...
Anybody have a recommendation as to which to go for.??
Thanks Dave.
Thanks Dave.
- Scubaregs
Bimmercode ??
Just get a wired ethernet connection to your phone rather than BT connection, the last thing you want is BT to drop for some reason whilst coding.
Have an iphone, so not sure which Android one to recommend.
Bimmercode ??
I have Carly. I think you can do a lot more with binmercode.
What are you looking to code in?
- raven
Bimmercode ??
More likely you'll get errors using the cable, it can be damaged from bending, get caught on something, fall out of the port.
BT connection doesn't break by itself all you have to do is stay in range, which is about 20m I believe
I use the OBDLink CX Bluetooth (my friend on android and me on iPhone) and it works great on both, I haven't had any issues with it.
2019 BMW Z4 G29 M40i @600hp - IG: ZZZZ_M40i
- Scubaregs
Bimmercode ??
Had BT drop connection on various devices, connected properly to the port it will never fall out and quite how you would damage a cable badly enough to cause a connection failure during use escapes me.
Only plausible scenario is "tugging" the lightning connector to the phone out, though the phone itself would need to be secured before the cable could be pulled out accidentally. My phone came out of my quadlock holder whilst "making good progress" on my bike and it stayed connected to the charging wire, dangling upside down, until I found a safe place to pull over and rectify it.
In the dozen or so times I've used Bimmercode so far none of the above scenarios have looked remotely possible.
- StanDiego
Bimmercode ??
Have any of you done any coding on the G29 with BimmerCode? I used it on my F57 2019 MINI Cooper S convertible with excellent results but have no experience on the G29.
2022 G29 s30i Black Sapphire Metallic / Magma Red / Shadowline / 799M Black spoke wheels "Darth ZEDer"
- Scubaregs
Bimmercode ??
Yep, coded stop/start to last setting, few other things.
- Reamesy
Bimmercode ??
I use this adapter
Vgate iCar Pro Bluetooth 4.0... https://www.amazon.co.uk/dp/B085Y5BBXX? ... b_ap_share
£23.60
Works perfectly with BimmerLink and bimmercode
£23.60
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
- srhutch
- Moderator
Bimmercode ??
I use a Vgate icar 2 wifi with bimmercode and andorid for my F11
- StanDiego
Bimmercode ??
The Veepeak OBDCheck Bluetooth scanner has worked well for me: https://www.amazon.com/dp/B073XKQQQW/re ... 7d01f975e8
Bimmercode ??
Anything that can be done that is useful?
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Scubaregs
Bimmercode ??
Did the cioding to bring up better sound in the stereo, can't remember offhand but maybe the menu for the Bilstein?
- StanDiego
Bimmercode ??
Perhaps Bowers and Wilkins?
- Scubaregs
Bimmercode ??
That's the chappie, knew it started with a B. Yes, I was at the pub yesterday.
Bimmercode ??
Just to update this thread, i got myself a bimmercode device, and coded the B+W sound, and sorted the start stop ..
The B+W sound upgrade is a way better than the previous settings, well worth doing.
