Using BMW Scanner 1.4 to change Transport Mode (or Energy Saving Mode) to Normal Mode.
This allows the Heated Rear Window and the A/C to work and the heater fan to work at all speeds.
In January this year ‘Colb’ said “Dealt with the Transport Mode first by using BMW Scanner 1.4 in the reprogramming menu of the module clicked on the 'Normal setting and it reverted the module to Normal and took the car out of Transport Mode instantly. As soon as it did the blower motor, heated rear screen and roof all became operational again. For those of you who have had problems clearing Transport mode I can now confirm BMW Scanner 1.4 will do the job.”
That is quite correct but for those, like me, who haven’t done it before some screen shots and explanation may make it easier.
Firstly some code readers call ‘Transport Mode’ - ‘Energy Saving Mode’. This is a better description because it usually happens when the battery charge gets low and it goes into this mode to save electrical power. Unfortunately it doesn’t come out of this mode automatically when the battery is recharged or replaced.
Most BMW specific code readers can read the code. Few can reset it. BMW Scanner 1.4 costs between £20 and £25. It is a plug to go into the OBDC2 port, a USB cable to connect it to a laptop and a CD or USB stick to provide the software. Its old fashioned equipment dating back to 2008 or before so was originally designed to run on Windows XP. I ran it on an old Dell laptop dating from 2009 which had Windows Professional 7 (32bit) operating system. New drivers need to be downloaded and the CD/USB Stick has instructions and video how to do this. One word of caution, having installed it all correctly clicking on the desktop icon to run BMW Scanner will give the error message “Hardware not found” unless it is plugged into the Z4s ODBC2 port. The ‘Hardware’ it is referring to is not what you have just bought but the Z4!
When connected switch on the ignition and start up BMW Scanner on the laptop. It will check you have switched on the ignition and the produce a Vehicle information Screen:- So you can see I have a facelift 2.5Si Sport in Titan Silver with Black leather MSport seats.
Click on Close and 3 pages of modules become available. Double Click on the words ‘Heater and Air conditioner Control’ and it will check the module. The picture below is after it had cleared transport mode. On the lefthand side is a button for ‘Errors’ , visible on picture 4 Click on that and you should see as below but where it says no erroes and a green square a red square and ‘FF [255] Energy saving mode active’. The picture below is what you will see when it’s out of ‘Transport Mode’. If you click on ‘Clear errors’, which works with everything else, it doesn’t clear it. Click Close and you get back to the screen below, click ‘Reprogramming’ and the ‘Used module programming’ box appears click on ‘Set unit mode’. That will bring up the box below click on ‘Normal (default) mode’ and click close. When you go back and click on Errors then the errors page comes up and should now show no errors and a green square as above. You should now have Heated rear window, A/C and a fan that makes a noise as you turn the knob. I understand BMW software can permanently delete ‘Transport Mode’ but BMW Scanner can only reset it, as far as I can find out. If the battery goes flat again you may have to do all this again. Either buy a trickle charger or drive the Z4 more often!!
- colb
Good writeup with screen shots.
To permenantly delete Transport Mode it has to be done with BMW software , INPA, DIS or SSS, bit more involved using these bits of software not explored deleting it with my kit but may explore it when I am feeling brave. Happy to have BMW Scanner 1.4 to hand just in case.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
I wrote it up so that I'll have a chance of remembering how I did it. Memory isn't what it used to be.
From what I can see in BMW Scanner it could be deleted by reprogramming the eprom. However that has to be done in hexadecimal with an understanding of BMW's software. As it's 50 years since I did programming in Hex I'll not attempt it!
- colb
I think NCS Expert will delete it, got to get your head around how that works, few videos on Youtube showing How To.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
I imagine you'd have to go into each module though?
NCS Dummy takes a lot of the hassle out
- dmo
Is there anything specific about the BMW Scanner 1.4 interface that connects to the car (https://www.ebay.co.uk/itm/364016033975), or is the magic all in the software?
I have a blue canbus reader that I bought a while back which cam with software - I'm wondering if I can download the BMW Scanner 1.4 from online and use the existing connection that I have.
If anyone knows - let me know?
BMW Z4 3.0si Sport Coupe (AUTO) (2006), Silver Grey FOR SALE
- enuff_zed
Need a dedicated cable for it, which then comes with the software on a usb stick too.dmo wrote: ↑Thu May 04, 2023 6:01 pm Is there anything specific about the BMW Scanner 1.4 interface that connects to the car (https://www.ebay.co.uk/itm/364016033975), or is the magic all in the software?
Not all of them work out of the box with Windows 10 so choose carefully.
I got this one:
https://www.ebay.co.uk/itm/154021453500
- dmo
What did you need it for? Transport mode too?enuff_zed wrote: ↑Thu May 04, 2023 6:08 pmNeed a dedicated cable for it, which then comes with the software on a usb stick too.dmo wrote: ↑Thu May 04, 2023 6:01 pm Is there anything specific about the BMW Scanner 1.4 interface that connects to the car (https://www.ebay.co.uk/itm/364016033975), or is the magic all in the software?
I got this one:
How did you go about setting it up? WinXp or Win10?
I was thinking to set up Tiny10 on an old laptop if I go down that route...
- enuff_zed
Got it for transport mode. Put it on an old W10 laptop
- dmo
It doesn't say E86 on the advert, but do you know if its works with the 2006 E86 coupe?enuff_zed wrote: ↑Thu May 04, 2023 6:08 pmNeed a dedicated cable for it, which then comes with the software on a usb stick too.dmo wrote: ↑Thu May 04, 2023 6:01 pm Is there anything specific about the BMW Scanner 1.4 interface that connects to the car (https://www.ebay.co.uk/itm/364016033975), or is the magic all in the software?
I got this one:
- enuff_zed
No idea. But why would it not? Just a roadster with a stuck roofdmo wrote: ↑Thu May 04, 2023 9:27 pmIt doesn't say E86 on the advert, but do you know if its works with the 2006 E86 coupe?enuff_zed wrote: ↑Thu May 04, 2023 6:08 pmNeed a dedicated cable for it, which then comes with the software on a usb stick too.dmo wrote: ↑Thu May 04, 2023 6:01 pm Is there anything specific about the BMW Scanner 1.4 interface that connects to the car (https://www.ebay.co.uk/itm/364016033975), or is the magic all in the software?
I got this one:
- dmo
Can't think of why it wouldn't, but then why wouldn't they just write E85 on the advert on eBay.enuff_zed wrote: ↑Thu May 04, 2023 9:40 pmNo idea. But why would it not? Just a roadster with a stuck roofdmo wrote: ↑Thu May 04, 2023 9:27 pmIt doesn't say E86 on the advert, but do you know if its works with the 2006 E86 coupe?enuff_zed wrote: ↑Thu May 04, 2023 6:08 pm Need a dedicated cable for it, which then comes with the software on a usb stick too.
I got this one:
I've asked the seller anyway. Will buy it tomorrow if they come back and have it sorted next week all being well.
Thanks for the reco
- colb
It should work on your E86 as well as E85 in fact it will read all BMW models.
The software sitting behind BMW Scanner 1.4 is PA Soft a well known diagnostic software.
It is the only code reader setup that I have found that can reset Transport Mode other than the BMW Software packages of INPA, NCS Expert and Winkpf and DIS which are somewhat complecated to set up and work your way through.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- dmo
I asked the seller on eBay and they've come back saying the e86 isn't supported. How weird. I was expecting them to confirm what I suspected, but turns out it's a no?colb wrote: ↑Thu May 04, 2023 10:20 pm It should work on your E86 as well as E85 in fact it will read all BMW models.
Do I risk it anyway and hope it works?
