CarPlay/AA MMI box with MOST connection
My installation video is now live
https://youtu.be/EY4XAzUYiXk
Dave
2011, 23i, Grey with Red leather.
- B21
Another great production thank you.AnubisZed wrote: ↑Fri Jun 10, 2022 1:23 pm My installation video is now live
Its really useful just seeing how to unclip various connectors and pull the dash / trim out.
I'll have it running this winter when I pull the interior apart / fit the DSP/carplay etc etc
Dave, what is the cable you said isn't needed? And is the coding of the head unit now possible as this box connects with the controller? I believe that was the #C cable connection with Andream boxAnubisZed wrote: ↑Fri Jun 10, 2022 1:23 pm My installation video is now live
Edit: I checked the cable that's been under my desk for over a year, it has a choice of plugs on one cable, instead of 2 alternative cables supplied by Mr12Volt
The extra cable is for the NBT controllers, works the same but has more pins on the plug into the controller.Roddy wrote: ↑Sat Jun 11, 2022 12:36 amDave, what is the cable you said isn't needed? And is the coding of the head unit now possible as this box connects with the controller? I believe that was the #C cable connection with Andream boxAnubisZed wrote: ↑Fri Jun 10, 2022 1:23 pm My installation video is now live
Yes indeed you can code/read the headunit normally with this box as it doesn't interfere with the canbus.
Dave
Thank youB21 wrote: ↑Fri Jun 10, 2022 3:37 pmAnother great production thank you.AnubisZed wrote: ↑Fri Jun 10, 2022 1:23 pm My installation video is now live
Yeah the installation of the box is very straightforward really, getting to stuff is where it can become complicated.
Dave
AnubisZed wrote: ↑Sat Jun 11, 2022 8:20 amThank youB21 wrote: ↑Fri Jun 10, 2022 3:37 pmAnother great production thank you.AnubisZed wrote: ↑Fri Jun 10, 2022 1:23 pm My installation video is now live
Great thread, post and vids as always Dave, I installed the previous aux which, I am quite happy with, is it worth changing to the most box
If it works fine and you're happy with it then don't change it. I only changed mine mainly for the channel content and curious to see if it would make a difference. If someone was in the position to buy one from scratch then yes defo go for this one
Dave
New direct links to the standard and new DSP boxes now on the first post as well as the installation video
Dave
- Ed.Straker
Very helpful, think I will follow and add one to the car too
White 35i MSport MHD re-map…still in one piece
Atacama Yellow 20i MSport Auto. Remapped, more to be done…written off
What is DSP Dave?
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
DSP = Digital Sound Processor (equalizer)
Some of the complaints from owners was that there was a lack of low end bass, so the manufacturer developed this second box as well. I have the standard box and just don't find this at all, the sound is spot on for my system. I'm thinking it could be something to do with the amplified systems (this was the US sites M3 group that posted the original thread on this subject and is currently on 42 pages) and this could affect it in some way, but my retrofitted standard system sounds just right.
Dave
Thanks Dave - to access the equaliser on that box do you have to mess around disconnecting from the car, adjusting it, reconnecting over and over till you get it right or is it accessible from the menu while connected?AnubisZed wrote: ↑Thu Jun 16, 2022 7:34 amDSP = Digital Sound Processor (equalizer)
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
All accessible from the menumcbutler wrote: ↑Thu Jun 16, 2022 9:17 amThanks Dave - to access the equaliser on that box do you have to mess around disconnecting from the car, adjusting it, reconnecting over and over till you get it right or is it accessible from the menu while connected?AnubisZed wrote: ↑Thu Jun 16, 2022 7:34 amDSP = Digital Sound Processor (equalizer)
EDIT** click video for demo... https://www.youtube.com/watch?v=MjEVnyuz2Z4&t=115s
Dave
- Wolter
Last update on this topic from my side and unfortunately not a positive one.Wolter wrote: ↑Tue Jun 07, 2022 9:58 am Just an other update from my side.
Received a complete new replacement unit this week.
After installing it (including new wiring etc.) I am experiencing the exact same issue as with previous box; glitching of the oem menu ‘s on the display after using the mr12volt box.
Video of box itself/carplay etc. remain ok.
The glitching gets worse the longer the box is in use up to a point the display does not show any oem menu display at all anymore (completely black or alternating black/red display)….frustrating.
As said, if I leave the box in operation the video remains ok and glitch-free. Issue only arrises after using the box and switching back to the oem system using the menu button.
Anyone else have installed a comparable box in comparable setup and experience no issues?
After some communication back and forth with mr12volt I decided to return the replacement box and ask for a refund.
There seems to be no solution for the glitching I was experiencing.
According to mr12volt it has probably something to do with the age of my car and they think “many funny things can happen over time” …
They told me that after 9 months of selling the box there where 5-7 reports of the same issue.
Anyways, the carplay functionality and super audio with lots of bass was not worth it for me due to the trade of i.e. constant glitching oem displays.
Btw great video Dave!
2010 E89 2.3i Tiefseeblau Metallic
1999 R1100S Marakesh Red
- B21
Bit of a pisser…sorry to hear it hasn’t worked out…I’ll have to wait till later this year to see if my unit has the same issue…
