Here’s a comparison between std & megane pads. Also how well they fit the Z4M disc!
Brembo Brake upgrade *Update
- Argenta
- Ed Doe
Well they're definitely a fair chunk bigger than oe
Sadly they're not the same pattern as the ap racing/btcc pads. Not to worry I'm sure as has been said some cooling mods and perhaps an even a pad compound with a bit more heat resistance should see you right. I think orange stuff is designed as an endurance pad and supposed to be very good for big temperatures?
EDIT - these are the ap racing pattern pad - same as the bmw performance 6pot ones, next to my old 3.0si pads for reference.
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- Argenta
Carbotech XP8 is my favourite for the track/street actually and I had them on my OEM setup too. I think only hard-core stuff like PFC 08, XP10 etc would stand heat better. So I think I'll keep my XP8 all around.
- Ed Doe
That's fair, totally up to you with use mix etc - but the reason you're running to the edge of the pad performance on track (in terms of heat and wear rate) will be the semi-slicks that's all!
- Argenta
