Dash cam
Dash cam
Looking at it, might spend a bit more and get the q800 which has higher res.Argyll Andy wrote: ↑Thu Feb 24, 2022 6:27 pmori, any particular reason for that one? Also what’s the advantage of the OBD install and does that have the battery protector built in?
Not sure about benefits of obd or other install, but a constant live feed is needed for parking mode. Obd tells it the car is off otherwise it waits for you to be stationary for five mins I think.
I’m looking at various companies. So far £299 installed is the best price I got. Prices vary wildly.
- BMWZ4MC
Dash cam
[quote=B21 post_id=<a href="tel:1907301">1907301</a> time=<a href="tel:1645714587">1645714587</a> user_id=38172]
[quote="Argyll Andy" post_id=<a href="tel:1907267">1907267</a> time=<a href="tel:1645708678">1645708678</a> user_id=32676]
[quote=B21 post_id=<a href="tel:1907265">1907265</a> time=<a href="tel:1645708201">1645708201</a> user_id=38172]
[quote="Argyll Andy" post_id=<a href="tel:1907262">1907262</a> time=<a href="tel:1645707737">1645707737</a> user_id=32676]
Peter, do you think that existing mount could be adapted/made to fit in/on the roll hoop since it’s so small?
[/quote]
Hi, I’m not sure hence my questions..the mini garmin is very compact..I hate those big things hanging down with a distracting screen…
I can’t work out whether the forward facing camera mount can simple swivel backwards..
Awaiting Ray comments …but given that the two cameras could be networked looks a cute idea..
The issue with a rear facing camera mounted on the hoop is that most are not water resistant so it’s an issue for us hard core top down motoring chaps..
[/quote]
I know the rear facing element of this covers rear passengers etc but I’m wondering if due to the small cabin size in the Z4 if the rear facing one would “catch” the images through the rear window when the top is up or is clear enough for the same when the roof is down.
https://www.halfords.com/technology/das ... 66398.html
Yes the waterproofness may be an issue for us up here. Suppose we’d just need to maintain enough speed to ensure the water blows over the car
[/quote]
Suck it and see?
I don't think there's a perfect solution...from the rear I'm more interested in capturing the rear enders that then push you into someone in front..hopefuly there would be enough resolution plus sound effects to determine such events?
[/quote]
I had a rear-facing dashcam in my S2000. I fixed it to the glass wind deflector between the head restraints. It worked very well but looked a little ugly!
[/quote]
[/quote]
[/quote]
Suck it and see?
[/quote]
S2000 GT - gone
- BMWZ4MC
Dash cam
The quoting system is working a charm, I see!
S2000 GT - gone
- Argyll Andy
Dash cam
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
OnlineB21
Dash cam
I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
I appreciate that compared to a headrest mounted or bumper mounted solution it will be inferior but probably better than nothing…
I’ll order the mini now and see what gives..
We choose to go to on with this endeavour at this time and do the other things, not because they are easy, but because they are hard..
- Argyll Andy
Dash cam
If you installed two individual units of these do you know if you’d be able to wire them both through the one voltage monitor/regulator unit that cuts the power to save the battery from going too low?B21 wrote: ↑Fri Feb 25, 2022 9:34 am I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
Dash cam
Hi BMWZ4MC, This is the camera mount supplied with the mini 2, two supplied along with cables and 12v adapter plug. On the Garmin drive app there is an option for “add another device” so I assume for extra camera.
- D944B0A6-728B-4744-9F60-6CF1D366B192.jpeg (58.73 KiB) Viewed 997 times
- 38C499BF-4FF4-41F4-AA53-DFADD0BDBE15.jpeg (98.48 KiB) Viewed 997 times
White e89 30i sdrive, Melbourne red e89 35is, 2021g29 sdrive 30i misano blue.
Dash cam
Additionally i have used other dash cams in other vehicles front and rear in my X5 and SQ5 some years back with great effect, was able to trace and prove a van hitting my SQ5 in the rear while parked in the street. When I showed the company that owned the van they paid the repair bill.
OnlineB21
Dash cam
YesArgyll Andy wrote: ↑Fri Feb 25, 2022 10:13 amIf you installed two individual units of these do you know if you’d be able to wire them both through the one voltage monitor/regulator unit that cuts the power to save the battery from going too low?B21 wrote: ↑Fri Feb 25, 2022 9:34 am I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
That’s unusually succinct..
- Argyll Andy
Dash cam
GoodB21 wrote: ↑Fri Feb 25, 2022 11:35 amYesArgyll Andy wrote: ↑Fri Feb 25, 2022 10:13 amIf you installed two individual units of these do you know if you’d be able to wire them both through the one voltage monitor/regulator unit that cuts the power to save the battery from going too low?B21 wrote: ↑Fri Feb 25, 2022 9:34 am I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
Yes, it is
- Argyll Andy
Dash cam
Ray, thanks for the pictures. Given that the mounting is on par with a pound coin it seems completely feasible that it could be mounted inside the roll hoops of the G29. I’m 99% sure they’re open, as in no mesh, as I think the wind deflector only goes between the hoops, not like the E89 where many have mesh inserts within the hoops
The one thing that will matter is the actual size of the unit in relation to the gap inside the hoops. I’ll need to go and measure when I’ve got a minute
Dash cam
Mine has the mesh sections inside the hoops - as seen in https://www.realoem.com/bmw/enUS/showpa ... Id=54_0590. I haven't investigated whether they come out easily; I suspect not without removing the hoop trim!Argyll Andy wrote: ↑Fri Feb 25, 2022 11:55 am I’m 99% sure they’re open, as in no mesh, as I think the wind deflector only goes between the hoops, not like the E89 where many have mesh inserts within the hoops
Would be interesting to see if anybody has mounted a camera there on a G29; I've been vaguely contemplating it, but since mine has the silver hoop trim a black camera might stick out like a sore thumb.
Dash cam
So I pushed the button on this and today ordered a Thinkware Q800 pro.
My reasons are that it looks neat. Comes with a parking mode and has built in (software controlled and adjustable) voltage protection. (Now the question is what do I set it to? 12v or 12.2?)
Hi resolution recording. 2k video recording.
No screen.
Added bonus is that it comes with speed camera warning.
Parking mode was super important to me as some of you know what happened to my last car.
No screen.
Dash cam
Just a quick update on this.
Had a call from RAC who are doing the install for me.
All confirmed for Friday, but they did advise me that on BMW after 2021, parking mode can trigger a battery drain warning on the car if left parked for a few days. This also depends on the camera settings and voltage cut off point.
