MAF has gone and the remap was done to enable the full de maf.
the tuner said it would be better to get the MAF as it would be a restriction. so all the air is coming through now the bigger hole. I think it's about 15 cms/6 inches.
you can run with a MAF but listening to folks on here they said get rid and re map.
it did get a bit lumpy down low revs in 3rd gear but a tune to the map got rid of that.
hope that helps.
Z4MC - Project YesNoYes
- grannyknot
Gottcha, I was looking at the pics from a few months ago.
So you are working with a Map sensor and Alpha N now?
2008 E86 M coupe
Toronto, Ontario
Toronto, Ontario
I have no idea. I just threw the problem at BMR to sort out.
there is a temp sensor in the air box as well as the map sensor I think. I don't think its Alpha N - maybe a ping back to the OEM ECU
I can ask and PM you
- grannyknot
