Bad radio reception
Bad radio reception
Hello
I’ve got an 2003 E85. Car has the CID navigation system and DSP sound system.
The radio suffers from bad reception.
When checking faults I get “ 000002 RAD: Fault in aerial power supply”.
I checked power supply for the radio amplifiers and they’ve got supply.
I removed all three amplifiers for the antennas and disassembled them to check for corrosion or other visual defects but not finding anything suspicious.
Anyone had issues like this and got a solution or a method for locating the faulty component?
- pvr
Bad radio reception
Which antenna are you checking? The one in the bumper or the one on the boot?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Bad radio reception
I haven’t checked any antenna, just looked at the amplifiers as the fault code tells me one doesn’t work. Replaced the rod without improvement.
Bad radio reception
I had a similar issue. Had to replace to antenna amplifiers to get reception working again.
2004 Z4 2.5i
2006 Z4 M Roadster
2017 X1 xDrive28i
2006 Z4 M Roadster
2017 X1 xDrive28i
Bad radio reception
Which one? Or did you replace all three of them?
Bad radio reception
The two in the left rear trunk. One attaches directly to the antenna and the other is connected and mounted a few inches away from the first one.
2004 Z4 2.5i
2006 Z4 M Roadster
2017 X1 xDrive28i
2006 Z4 M Roadster
2017 X1 xDrive28i
Bad radio reception
OK. You didn’t locate the problem to one of them? Just replaced both at the same time?
There’s one between the “large” amplifier and the rear “bumper”-antenna. Two cables attached. That one you didn’t replace?
Bad radio reception
Correct - I could not determine which was bad or if both were. Here are the two I replaced
2004 Z4 2.5i
2006 Z4 M Roadster
2017 X1 xDrive28i
2006 Z4 M Roadster
2017 X1 xDrive28i
Bad radio reception
Replaced the diversity module now (the large one) and it works again
I’ve seen some people getting a list of radio stations in the CID. I don’t do so. Is it an option or is it only available on facelift cars?
Bad radio reception
Did you have a fault code or just poor reception; and, did you replace them with new units or second-hand?tomjonesBT33 wrote: ↑Thu Feb 03, 2022 12:03 pm I had a similar issue. Had to replace to antenna amplifiers to get reception working again.
Bad radio reception
I've got an issue with no radio signal in my e85. Tried to replace to stubby but no luck
How best to diagnose the issue and tomjonesBT33 where did you get the parts?
2007 ///M Roadster
@mz4yyp
@mz4yyp
