- Koni Special Active Dampers
Quaife ATB rear differential
VRSF downpipes
Mishimoto intercooler
Masata chargepipe
Burger DC intake
MHD Stage 2+
I took the seats out so I could clean the carpets It definitely needed doing, as you can see! I updated the still 2010 maps I replaced this outer seal on the boot I ripped this stupid thing out. It was quite reluctant to leave the vehicle! I replaced the above with this. I used to manage fine having a car without a cup holder, but not now. It doesn't make me a bad person. While I had the centre console apart I replaced the USB/AUX input. No idea what befell the old one, but I am sure you can see why it wasn't working. Other things that have happened:
I have put a set of Michelin PS4's on the back. They don't match the Goodyears that are still on the front, but I've never had an issue mixing front and rear, and the front will get PS4's when required.
I re-flashed the map from stage 2+ down to stage 1. I don't mind admitting the claimed 420bhp was a bit terrifying, especially at this time of year. Of course, it wasn't helped by the nearly bald Goodyears it had on the back until I replaced them!
Things happening imminently:
The car is in a nearby garage today for a thorough checking over. Not one I have used before, but they are a Merc/BMW specialist and they have a fantastic reputation (https://goo.gl/maps/DoxJgyPHEQN7t1PTA)
I know it needs new rear discs & pads, and I suspect something is worn in the front suspension. I'm also ready for them finding any signs of leaks, but hopefully nothing too dramatic for my wallet.
Things happening in the near future:
Fitting an Android screen - this weekend. Will also include removing the existing CarPlay piggyback system, hopefully easy to find!
Fitting LCI side indicators - probably this weekend, depending how well the above goes.
Replacing door top seals - I'll have to establish to what extent the door needs taking apart before tackling this.
Thing happening as soon as possible:
Audio upgrade - realistically I think I'm going to get someone to do this for me. I have three young kids, so there's a limit to the time I can put into doing things myself. The car has base audio, so it needs new speakers, an amp, a DSP and doors taking apart for sound deadening. How much I can spend on that lot will be determined on how many issues the garage find today!
