Run flat rears only?
I need 2 rear tyres soon and want to change to non R/F. I will change front as needed. Will I have any handling problems?
- B21
Long and frequent debate but the bottom line is you shouldn’t do it…your front and rear should have a similar construction, a similar tyre compound and ideally the same type from one manufacturer.
These are relatively high performance cars, not TESCO run only shoppers.
All IMHO
All IMHO
Thank you for your reply, l will go with your advice.
- B21
Splendid, we like our Forum members to live long and prosper!
Plenty of advice on tyres here, depending on your budget /driving style etc..
OnlineOle gits rule
Good and sensible advice - always use the same tyres for front and rear
M4 Vert in Yas Marina Blue
I'm always going to opt for front and rear, don't see the point otherwise. Just my personal opinion.
it's just the cost of 4 tyres when I only need 2. I understand the safety reasons but I might have to go with 2 new run flats for now and hope all 4 wear down at the same time
- enuff_zed
Hi Fred, welcome to the forum.Fred the Z wrote: ↑Wed Feb 02, 2022 4:16 pm it's just the cost of 4 tyres when I only need 2. I understand the safety reasons but I might have to go with 2 new run flats for now and hope all 4 wear down at the same time
Whereabouts are you and what sort of zed do you have?
Maybe a chance someone may have a pair of front wheels with non-runflats on that you could, buy, borrow, lease etc. to give you time to spread the costs of your new ones?
OnlineArgyll Andy
Hello and welcome Fred, unfortunately the 4 are very unlikely to wear at the same rate. RWD with a reasonable amount of power is likely to see the fronts have twice the life than rears. In fact, exactly what you’re possibly suffering from atm.Fred the Z wrote: ↑Wed Feb 02, 2022 4:16 pm it's just the cost of 4 tyres when I only need 2. I understand the safety reasons but I might have to go with 2 new run flats for now and hope all 4 wear down at the same time
One option is the fronts go on eBay/gumtree/Facebook as there’s a healthy enough market for runflats away from the forum.
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- sars
Yes there is an argument that you should not mix tyres front and rear, as in keeping the same make and model all round. There is another argument in that if you have a staggered set up your front tyres will behave differently to your rears AND your handling will be be different if you had a square set up (staggered tends towards understeer and square tends towards oversteer). Every model of zed, new and old can be had with either a square or staggered set up, thus logically I don't see much of a difference in running different brands front and rear, just buy the best tyres you can afford.
What you absolutely should not do is run different tyres on the same axle.
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
To prosper is nice and living long is a bonus.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
