Salmon Relay Change
Dave 2 dogs
Salmon Relay Change
Post by Dave 2 dogs » Thu Dec 30, 2021 11:00 am
Excellent
Thanks guys
It seems a MUST DO job . Thanks for the info :thumbsup:
BeardyJon
Salmon Relay Change
Post by BeardyJon » Thu Dec 30, 2021 1:22 pm
Yeah definitely must do. The salmon relays eventually basically rust shut meaning the roof motor runs constantly and you can't open the boot and your battery drains until its dead. So... replace them relays!
2012 E89 sDrive20i M Sport Celtic Tuning Stage 3 Remap
2008 E86 Z4 M Sport 2.0i - Gone
2003 E46 316ti M Sport - Gone
Smartbear
Salmon Relay Change
Post by Smartbear » Thu Dec 30, 2021 2:42 pm
BeardyJon wrote: Thu Dec 30, 2021 1:22 pm Yeah definitely must do. The salmon relays eventually basically rust shut meaning the roof motor runs constantly and you can't open the boot and your battery drains until its dead. So... replace them relays!
It’s not rust that’s the problem, the large current draw burns the contacts of the relays & they can end up arc welded together.
e85 3.0si sold
peeblezZ4
Salmon Relay Change
Post by peeblezZ4 » Thu Dec 30, 2021 6:34 pm
Stuart, you don’t actually need to unscrew anything, there’s a quick release lever. If you push that the whole housing with the relays in it slides out, switch the relays over then slide back in place until it locks home :thumbsup:
Thanks Andy. ETA for the relay delivery is 6th Jan so I'll get it done then. :thumbsup:
Current - '10 Sapphire E89 3.0 Manual M-Sport
Previous:
'12 Space Grey 640i Auto SE Cab :? Sold March '24
'11 E89 Sapphire 35i auto M-Sport :heat: Sold August '23
'13 E89 Valencia 2.0 auto M-Sport :?
'03 E85 Titanium 2.5i auto :?
BeardyJon
Salmon Relay Change
Post by BeardyJon » Fri Dec 31, 2021 12:46 am
Smartbear wrote: Thu Dec 30, 2021 2:42 pm
Same thing...
Smartbear
Salmon Relay Change
Post by Smartbear » Fri Dec 31, 2021 12:51 am
BeardyJon wrote: Fri Dec 31, 2021 12:46 am
Same thing...
The end result's the same, different means of getting there :thumbsup:
e85 3.0si sold
B21
Salmon Relay Change
Post by B21 » Fri Dec 31, 2021 10:17 am
Smartbear wrote: Fri Dec 31, 2021 12:51 am
Same thing...
SmartBear is being generous…actually it does matter…
With rust associated failure (if it ever happened) the circuit would fail open..ie the roof fails to operate..
However with arcing the danger is the contacts weld together making the pump run to oblivion ..
Ergo it does matter.. :thumbsup:
A very modified Atacama Yellow 35is :thumbsup:
BeardyJon
Salmon Relay Change
Post by BeardyJon » Fri Dec 31, 2021 10:59 am
B21 wrote: Fri Dec 31, 2021 10:17 am Ergo it does matter.. :thumbsup:
Everyone loves a pedant. :poke:
B21
Salmon Relay Change
Post by B21 » Fri Dec 31, 2021 2:59 pm
BeardyJon wrote: Fri Dec 31, 2021 10:59 am
Happy New Year to you too :rofl:
“Never let the facts get in the way of an unsubstantiated opinion” :thumbsup:
BeardyJon
Salmon Relay Change
Post by BeardyJon » Fri Dec 31, 2021 6:20 pm
B21 wrote: Fri Dec 31, 2021 2:59 pm
Interesting that you’re suddenly so concerned about facts when you got caught trying to flog an overpriced Z4 lying about its condition and not disclosing its major mechanical problems…
B21
Salmon Relay Change
Post by B21 » Fri Dec 31, 2021 6:32 pm
BeardyJon wrote: Fri Dec 31, 2021 6:20 pm
BeardyJon wrote: Fri Dec 31, 2021 10:59 am Everyone loves a pedant. :poke:
Oohhhh…meoww…goodwill to all men :rofl: :thumbsup:
peeblezZ4
Salmon Relay Change
Post by peeblezZ4 » Wed Jan 26, 2022 3:00 pm
[/quote]
Hi Andy. Went out and swapped in the new ones earlier today - thanks for your tip. A wee push out of the plastic lever and then lift the housing out after pushing back the bracket wee bit to get enough room. :thumbsup:
Previous:
Argyll Andy
Salmon Relay Change
Post by Argyll Andy » Wed Jan 26, 2022 4:55 pm
peeblezZ4 wrote: Wed Jan 26, 2022 3:00 pm Stuart, you don’t actually need to unscrew anything, there’s a quick release lever. If you push that the whole housing with the relays in it slides out, switch the relays over then slide back in place until it locks home :thumbsup:
[/quote]
Glad it was nice and easy Stuart and now some peace of mind knowing they’re done :thumbsup:
    E89 23i sDrive, Silver (Gone)
    RobbiZ4
    Salmon Relay Change
    Post by RobbiZ4 » Wed Jan 26, 2022 5:15 pm
    flybobbie wrote: Mon Dec 27, 2021 2:09 pm ...but later found there is a component across the coil.
    Can someone look at an old relay, is it a diode or resistor?
    Did anybody answer this question before?
    Well, there is a resistor in parallel to the coil.
    More background details:
    viewtopic.php?p=1900147#p1900147
    Pardon, je suis Allemand :oops:
    :ant:
    E89 Roof Maintenance
    viewtopic.php?t=130932
    Y3 Roof Diagnostic System
    viewtopic.php?f=23&t=129048
    B21
    Salmon Relay Change
    Post by B21 » Wed Jan 26, 2022 5:45 pm
    RobbiZ4 wrote: Wed Jan 26, 2022 5:15 pm
    The CTM sends a short current pulse to all the relays and solenoids before starting a roof operation. With these resistors, it can check the availability of these components as well as the wires to it. Same with most of the different sensors.
    On the following charts, these pulses can be seen for the 3 solenoids of the hydraulic pump on chart 3...5, later on chart 1+2 for both relays.
    Robbi..not sure if you have seen the UK TV program 'Master Mind' https://www.bbc.co.uk/programmes/b006mk1s
    You should do the 20 questions on ' The life and times of the E89 Roof System' :thumbsup:
