Tyre inflator
- GJ1
Tyre inflator
Hello all,
I am after some advice on purchasing a new tyre inflator please. The one I currently have takes so long to unscrew, all whilst I hear the air escaping, that I'd like to get one which has a quick release mechanism. Any recommendations? Ideally looking for something under £50. Alternatively, I've seen some adapters that I think you can connect to the inflator and tyre cap. Anyone have any experience of these? Do they do the job? Any recommendations?
Looking for either a car lighter plug-in or mains connection.
Thanks in advance
Thanks in advance
07 Z4C 3.0si sport sapphire black
- Argyll Andy
Tyre inflator
Maybe worth a punt but I had this with my recently purchased one and discovered if you push the braided hose back down onto the valve while unscrewing it largely stops any air escaping
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- GJ1
- Ewazix
Tyre inflator
I found the same push-down trick works, or adding +1 psi is usually about right to compensate.Argyll Andy wrote: ↑Fri Dec 10, 2021 10:01 pm Maybe worth a punt but I had this with my recently purchased one and discovered if you push the braided hose back down onto the valve while unscrewing it largely stops any air escaping
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- M1k3yC
Tyre inflator
I have this issue with mine but what I've noticed is that I think it slightly overinflates automatically (probably to compensate) when I set it to the pressure I want to achieve and use the auto-stop feature it has. I would suggest finding an amount to overinflate by that you are happy with then as long as each tyre loses roughly the same amount when you unscrew the hose it doesn't really matter. Tyre pressures fluctuate quite a bit with temperature anyway.
2022 Hyundai Kona N - greyhound transport
2018 F56 Mini JCW
2016 MX-5 2.0 Sport Recaro
Gone to a good home: 2007 E86 3.0Si Sport
2018 F56 Mini JCW
- mr.tourette
Tyre inflator
Yep..mine also over inflates by about 0.5psi to compensate, think this is common with digital inflators and makes senseM1k3yC wrote: ↑Mon Dec 13, 2021 12:44 pm I have this issue with mine but what I've noticed is that I think it slightly overinflates automatically (probably to compensate) when I set it to the pressure I want to achieve and use the auto-stop feature it has. I would suggest finding an amount to overinflate by that you are happy with then as long as each tyre loses roughly the same amount when you unscrew the hose it doesn't really matter. Tyre pressures fluctuate quite a bit with temperature anyway.
- enuff_zed
Tyre inflator
After much faffing about with various devices, I now carry an 'Airman' kit in the car, but for general tyre inflation I use a separate push on pressure gauge, but use a stirrup pump designed for pushbikes to inflate the tyre.
Find it just as quick and easy, and they come with the lever on the end, so you push it on then flick the lever round to open the valve.
For sticking a few psi in its quicker than unravelling the plug in type.
Tyre inflator
I’m with you on the stirrup pump, easy as and saves going to the gym for a work out. Along with a reliable pressure gauge used one for years when I was racing.enuff_zed wrote: ↑Mon Dec 13, 2021 1:19 pm After much faffing about with various devices, I now carry an 'Airman' kit in the car, but for general tyre inflation I use a separate push on pressure gauge, but use a stirrup pump designed for pushbikes to inflate the tyre.
2003 Toledo Blue 3.0 E85 Manual
2008 Volvo V50 - Dog Car
2020 Kia Sportage GT - Her Indoor’s Car
1995 Dakar Yellow M3 E36 Race Car - Sold
2009 Vauxhall Astra VXR - Sold
2003 350Z well modded - Sold
1992 911 RS - Sold and still in mourning
- GJ1
Tyre inflator
mr.tourette wrote: ↑Mon Dec 13, 2021 1:01 pmYep..mine also over inflates by about 0.5psi to compensate, think this is common with digital inflators and makes senseM1k3yC wrote: ↑Mon Dec 13, 2021 12:44 pm I have this issue with mine but what I've noticed is that I think it slightly overinflates automatically (probably to compensate) when I set it to the pressure I want to achieve and use the auto-stop feature it has. I would suggest finding an amount to overinflate by that you are happy with then as long as each tyre loses roughly the same amount when you unscrew the hose it doesn't really matter. Tyre pressures fluctuate quite a bit with temperature anyway.
Probably a dumb question but how do you tell it automatically over compensates? If you pre-set to say 30 psi does it flash up that it has put say 30.5 psi in? I've not noticed this on mine but might have just missed it or maybe mine's not clever enough for that.
- mr.tourette
Tyre inflator
Yes it has a digital display which shows 0.5 psi over whatever you set it at when it automatically stopsGJ1 wrote: ↑Tue Dec 14, 2021 11:37 pmmr.tourette wrote: ↑Mon Dec 13, 2021 1:01 pmYep..mine also over inflates by about 0.5psi to compensate, think this is common with digital inflators and makes senseM1k3yC wrote: ↑Mon Dec 13, 2021 12:44 pm I have this issue with mine but what I've noticed is that I think it slightly overinflates automatically (probably to compensate) when I set it to the pressure I want to achieve and use the auto-stop feature it has. I would suggest finding an amount to overinflate by that you are happy with then as long as each tyre loses roughly the same amount when you unscrew the hose it doesn't really matter. Tyre pressures fluctuate quite a bit with temperature anyway.
- GJ1
Tyre inflator
Ok, thanks for confirmingmr.tourette wrote: ↑Wed Dec 15, 2021 9:28 amYes it has a digital display which shows 0.5 psi over whatever you set it at when it automatically stopsGJ1 wrote: ↑Tue Dec 14, 2021 11:37 pmmr.tourette wrote: ↑Mon Dec 13, 2021 1:01 pm
