Roof won't retract
Roof won't retract
Hi All !!!!
Got the roof motor out ,relocated, and the hydraulic topped off. Pushed the retract button---nothing. Windows did not go down and it did not unlatch.
Figured if motor was bad it would go through the window, latch routine anyway. Thought that perhaps the previous low fluid level was cause of retraction failure.
All ideas very welcome.
- enuff_zed
Roof won't retract
Morning.
First thing to check, is the microswitch on the parcel shelf correctly located and operating?
Very easy to put the parcel shelf back in wrongly aligned in the slot.
Assuming you have actually put the shelf back? If not, then close the switch with a suitable item (I used an old wheel nut) and see if it works then.
Roof won't retract
enuff_zed:
I thought of that this morning.---I think you are right on target The shelf is still out. Where do I find the micro switch?
- rdm05z4
Roof won't retract
The Micro Switch is located about midway in the boot bulk head. Just do a search in the forum for Micro Switch or even Youtube for z4 Micro Switch and you will see where it is and how operates. My Switch went bad and as your case nothing worked until replaced. Good Luck,
2005 3.0i Manual, Sterling Gray Metallic Sport suspension, heated seats, top line Business Cd radio
2007 Nissan Maxima -Silver-Auto
2009 VW Wolfsburg Jetta-Black-6sp manual
- enuff_zed
Roof won't retract
In this case, it is not failed, just nothing there to operate it.rdm05z4 wrote: ↑Wed Nov 24, 2021 6:34 pm The Micro Switch is located about midway in the boot bulk head. Just do a search in the forum for Micro Switch or even Youtube for z4 Micro Switch and you will see where it is and how operates. My Switch went bad and as your case nothing worked until replaced. Good Luck,
I can understand you want to check everything before you reassemble it so look for the vertical slot in the middle of the forward boot wall. You'll see a small curved metal bit sticking out. Wedge it back using something as I suggested and your roof should work.
Roof won't retract
Thanks enuff_zed & rdm05z4. Will be checking the switch out in couple of days.
Thanksgiving tomorrow , Turkey & football (NFL)--not the REAL football..
Appreciate the help.
- enuff_zed
Roof won't retract
Enjoy your turkey and 'football'.
Let us know how you get on, with the car I mean..........
Roof won't retract
Back at it today.
Wedged the microswitch, pushed/held button for top down, windows went down, but no unlatch.
Tried to separate motor from pump. 1 allan screw had been previously stripped, wrench just went around. Managed to get a star wrench in and biting well, but could not loosen. Obviously had been overtightened by some previous owner/ mechanic.
I'm going to have to remove the hydraulic lines from the pump to take the unit out and put in vise for bolt removal.
Will there be a back flow of hydraulic oil into the boot/trunk ? Trying to avoid a big mess if I can.
Thinking I can remove lines from pump into a container for the limited back flow if any.
If successful, is there a way to bleed the lines after reassembly of new motor to hydraulic pump ?
This is almost as much fun as working on a sailboat !!!!! But not upside down as much !!
All thoughts /experiences welcome !
- Smartbear
Roof won't retract
I think the pump self bleeds when operated.
e85 3.0si sold
Roof won't retract
Would anyone know the specs for the 2 small bolts that hold the motor to the pump, or a resource I can search.
I got it apart, but one bolt had its allen socket stripped, now got to replace.
Got very little hydraulic oil flow back when disconnected the lines.
Any clues about locating the holes in the bolts that hold the 4 lines to pump ?
Making progress.
Making progress.
Roof won't retract
Installed new pump motor. Hit retract button--windows down, no unlatching.
Checked pump (now in boot/trunk)--low oil--added more---button light flashing--windows go down, no unlatching, no retraction.
Leave garage for home----1/2 mile away, roof decides to start retracting--pull over--roof successfully retracts completely
Pitch dark, rain is starting. Roof will not go back up.
Return to garage (daughter's)
Saga will continue tomorrow.
More hydraulic oil will be needed, I'm sure.
Should the unlatching work even with low oil ?
I will depress the brass button on the pump so I can raise the roof manually---thankfully in the trunk now.
Any ideas out there ?
- enuff_zed
Roof won't retract
Hmmm, I think I'd be looking to the wiring along the side of the roof for any damage.
Are you 100% certain you haven't kinked a hose or damaged any wiring while you were moving it?
- bigwinn
Roof won't retract
Took the words right out of my mouth
I'll post my thread up from the same issue
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- bigwinn
Roof won't retract
EWS Delete PM me
EWS Delete PM me
