Anybody know the correct fixings that should be in these holes and where i might get them? Looks like at some point someone has just used some bolts and washers and missed some out altogether.
Cheers.
Missing fixings.
- markplant
Missing fixings.
They should be expanding rivets,
Missing fixings.
It will tidy up the engine bay if you use the correct rivets or fleabay equivalents. They can be a pain in the ar*e if the plastic cover is not exactly aligned, as the rivets (which screw in) can twist and bend, and break. Have a couple of extras handy.
2003 Maldives Blue 3.0i auto
- enuff_zed
Missing fixings.
You don't have to screw them in. They are designed to screw out. But to fit them, place them squarely in the hole then use something like the end of a screwdriver handle and sharply tap them straight down.
I used these:
https://www.ebay.co.uk/itm/371743089000
Missing fixings.
Good to know, every day is a school day.enuff_zed wrote: ↑Sat Nov 20, 2021 9:00 pmYou don't have to screw them in. They are designed to screw out. But to fit them, place them squarely in the hole then use something like the end of a screwdriver handle and sharply tap them straight down.
I used these:
- Danz4coupe
Missing fixings.
Thanks I'll get some asap
