35i Track Weapon Build Thread
huseyin88
Post by huseyin88 » Fri Nov 05, 2021 3:28 pm
B21 wrote: Fri Nov 05, 2021 11:35 am Interesting article on Spoolstreet where the ultimate techies hang out , on cooling management..enjoy
https://www.spoolstreet.com/threads/n54 ... -use.4352/
Amazing find.
Really appreciate it B21.. although I feel a bit sad by seeing no real resolution but loads of interesting facts :cry:
I have however found a ER kit with twin coolers one each side of the car increasing capacity to 700% stock... pricey though.. but defo caught my eye... and the single kit alone increases it to 350%..
I'm going to probably get the single kit for now and then if not enough upgrade to the twin by buying another rad and daisy chain them together.
My oil changes are going to cost a bomb!
Z35is: RIP car fire :(
Z4 35i: Weekend / Track Weapon
Insta: https://www.instagram.com/bhp_life/
Youtube: https://www.youtube.com/channel/UCpkOR9 ... lRroPHiL1A
Build Thread: viewtopic.php?p=1880786#p1880786
huseyin88
Post by huseyin88 » Fri Nov 05, 2021 3:41 pm
Miyli wrote: Fri Nov 05, 2021 12:36 pm I added Mishimoto alongside the original and I ordered oil hoses of my own dimensions.
Here's a link to my log too. https://datazap.me/u/mikyli/log-1619594 ... 0-11-12-22
Nice setup there. I have seen a few people running the cooler across the top there. my issue would be that i ordered the SSP DCT cooler which will mount there.
So wont be able to use that space
I want to utilise the original engine oil cooler location with better rads to not block more of the front end as i already have a wagner evo II intercooler as well.
The ER rads seem to be 3.5x bigger core so should help, if a single doesnt ill daisy chain them and run another on the other side as nothing sits on that side of the front of the car. (if i end up going with this setup)
There are still setrab, mocal and mishi rads as well for a fraction of the ER rads price.. just need some dimensions on them all to see what it works out to and see which rad is best bang for buck as they are all decent companies.
:thumbsup:
huseyin88
Post by huseyin88 » Sat Nov 06, 2021 9:40 pm
Phase 1:
DECIDE ON PHASE1 MOD'S ROUTE
Choices:
-Which dipstick model to use?
Will have a read up and measure up and see what fits well enough then get it welded to the sump.
-Oil pressure during high G's solution? - Going with Accusump - Install location to be confirmed but not in engine bay either way
NO - Baffled sump:
- Vac seem to have bad rep and reviews on quality control with endless N54 issues after install.
- None of the baffle setups seemed to of resolved the issues for hard braking on left turns this was on slicks and even cup2's, detailed thread here:
https://www.spoolstreet.com/threads/add ... 34/page-16
YES - Accupump
- Electronic if I did choose this route but dont fancy it due to the size, however have seen installs in boots and other areas which wont be as bad.
NO - Dry sump
- Havent seen any setups yet anywhere to be honest not that I've checked in depth.. but this may end up being the solution.
ORDER ALL PARTS:
Pending Items:
Oil Filter Housing Gasket
Dipstick & Parts (need to pick a setup)
Oil pressure solution (CHOSEN) - Chosen to go with 3 QRT Accusum ECP 55-60PSI - Ordered
All other parts for the below items apart from fluids are ordered and should be with me in the next week or two.
Order Any Special Tools Required:
Pump to fill the DCT transmission once filters changed along with other work.
Works List:
Get New Sump & Send Off For Mods / Welding
SSP DCT Cooler Install
DCT Pressure Filter Change
DCT Internal Filter Change
DCT Sump Gasket Change
Engine CSF Radiator Install
Thermostat Gasket Change
Oil Filter Housing Gasket Change
O Rings Changed
Mosselman Thermostat Install
BMS Oil Filter Housing/Cap
Oil Pressure Sensor Install
Engine Oil Cooler - Single/Double Install
Sump Oil Pressure Solution? (Baffled Sump?) Install
Sump Dipstick Mod
Engine Sump Gasket's All Changed
Boomsticks
Post by Boomsticks » Sun Nov 07, 2021 1:26 pm
I use liqui moly 5w40 leichtlauf high tech oil along with a setrab 26 row front mount cooler with a block off plate, csf radiator with Evans waterless coolant. I have the car serviced every 4k. My temps are fine on fast road and track even in the peak of summer.
huseyin88
Post by huseyin88 » Sun Nov 07, 2021 9:29 pm
Boomsticks wrote: Sun Nov 07, 2021 1:26 pm I use liqui moly 5w40 leichtlauf high tech oil along with a setrab 26 row front mount cooler with a block off plate, csf radiator with Evans waterless coolant. I have the car serviced every 4k. My temps are fine on fast road and track even in the peak of summer.
Nice :thumbsup:
Heard good things about setrab and mocal coolers althought never used them myself.
How much power you running at the moment on your build as im looking to get to 700bhp hopefully on pump fuel and trying to get the cooling done from now rather than have to add again later?
Any data to show what temps you get on track with the days temp as well on a hot lap by any chance?
Have you had any oil starvation issues on track on hard braking or trail braking in to corners and specially left turns by any chance?
Also just wondering how often you go track as I'm trying to do 1-2 sessions a month on average so need it all bullet proof without the engine going poof :cry:
R.E92
Post by R.E92 » Sun Nov 07, 2021 9:52 pm
Asbjorn is the main to talk to about making a Z4 work on the track. He has a thread over on SpoolStreet (https://www.spoolstreet.com/threads/z4- ... uild.3026/)
His car is about 420whp. I think your power goals aren't compatible with your track intentions though. For 700bhp (600whp~) you will need some large twins or a single turbo. The twins would be more suitable for track work than a laggy single turbo but you're going to get some serious heat issues with that on track as you'll need to push them quite hard.
I think Asbjorn went through a lot of iterations of his cooling setup and is probably starting to get limited by his frontal area. You'd have no problems with 600whp on the street but on a track it's asking a lot.
huseyin88
Post by huseyin88 » Sun Nov 07, 2021 10:15 pm
Twins will the be the way im going as i've had a large single before and never again.
Regarding heat I will be creating custom body work in the later phases of the project to push / pull air including flat floor and tunnels to help with mechanical grip, but will only be doing that once most the engine and mechanical stuff is complete so i can place vents/ducts in hottest areas i see as i'll be logging via heat cam after track sessions to see where heat builds up and goes the most then redirect where i can away.
Ironically the thread you just posted also talks and makes mention of ducts and vents in the last few posts.
I'm not fairly set with the cooling setup i've purchased and just need the engine oil coolers im after and fairly sure it will last the 700bhp with a bit of ducting and shrouding to channel the air flow.
Proposed setup:
Ordered - DCT Oil - SSP kit (cooler, sump and pump) which should be enough and mounted behind the front kidneys
Ordered - Engine Coolant - CSF Rad
Trying to find - Oil Cooler - Considering Evolution Racewerks dual comp setup Each rad is 3.5x larger than stock so together 7x (700%) increased core
Ordered - Accusump 55-60PSI electronic pump to keep pressures where they should be during heavy braking and hard left turns
All the above will have some sort of shrouds to channel air directly do them along with grill spaces expanded to maximise air flow to them.
Yet to be designed properly and configured but ideally:
Bonnet vent to suck air out
Lower vents to pull air down from car
Ducts channelling air from bay to side of car possibly wheel arches where vents above will allow air out with trapped air in wheel wells
I'm not keen on having fans behind/in front of coolers as i havent seen them do any of my previous builds any good but that could of been how i had them setup/configured so if i run out of options can integrate something in.
Alongside that can also have water mist spray cooling setups in front of the coolers to help
huseyin88
Post by huseyin88 » Sun Jan 02, 2022 7:29 pm
So waiting for my garage to come hopefully by end of Jan.
Got all the cooling setup now just waiting for a few last bits which should do the trick.
Last track day at donington in December got cancelled due to fog :/ so couldnt get any logs.
Garage comes on the 24th hopefully and next track day is on the 5th Feb.. Bit tight but may see if I can get some of the bits in there...
Will sort pics out once I find a free hosting service or way of doing it.. unless anyone has any tips or advice?
Jollyjoiner
Post by Jollyjoiner » Sun Jan 02, 2022 7:58 pm
Me and Neil from here came down to Donington on that fog hit track day to have a breakfast and watch a few cars but all we got was a walk up and down the garages having a look at what was there. Was yours the white e89 in one of the bottom garages then ?
2009 35i DCT silver
SLT mapped to 365bhp :)
huseyin88
Post by huseyin88 » Sun Jan 02, 2022 11:44 pm
Jollyjoiner wrote: Sun Jan 02, 2022 7:58 pm Me and Neil from here came down to Donington on that fog hit track day to have a breakfast and watch a few cars but all we got was a walk up and down the garages having a look at what was there. Was yours the white e89 in one of the bottom garages then ?
Yeop that was mine :D
White with carbon wing and yellow tow straps :?
We was sat there praying and hoping would clear up :rofl:
Jollyjoiner
Post by Jollyjoiner » Mon Jan 03, 2022 4:36 pm
huseyin88 wrote: Sun Jan 02, 2022 11:44 pm
Thats it with the BIG rear wing. My car was a silver 35i with black roof parked near canteen :thumbsup:
2009 35i DCT silver
john-e89
Post by john-e89 » Mon Jan 03, 2022 5:07 pm
When isn't it Nige.....???? :poke: :poke: :evil:
MR2 MK 2
E89 35is
G29
Jollyjoiner
Post by Jollyjoiner » Mon Jan 03, 2022 6:38 pm
john-e89 wrote: Mon Jan 03, 2022 5:07 pm My car was a silver 35i with black roof parked near canteen :thumbsup:
A powerful boby like mine needs plenty of fuel to keep it going John :rofl:
Still waiting for your invite for a brew :wink:
2009 35i DCT silver
huseyin88
Post by huseyin88 » Fri Jan 07, 2022 2:14 am
LOL you guys! :rofl:
huseyin88
Post by huseyin88 » Thu Dec 08, 2022 9:43 am
Well not the updated i wanted to leave but half way through the year i think one of my turbos went and came out my exhaust on a track day LOL.
So my cars been sat there whilst ive been battling House DIY and building my garage so i can actually work on.
Hopefully by the end of this year i'll have it finished as im at the storage and layout phase now with a few more sockets and lights to put up.
Will need a full engine strip down assessment and then rebuild which is a perfect time to go for stronger internals for the end goal as well as Turbos whilst its all out. Whicccccch then starts the ultimate wallet death trap for any project "whilst im there i might as well..."
I guess lets see where it all goes and how broke i get lol!
