M54 coolant- not seen this before?
Onlinebigwinn
Morning all
Finished the vanos marathon on the aero car
Final piece of the puzzle was as always a new expansion tank. Fitted and done, used the old level sensor.
Restarted the car and all good apart from showing a coolant level light and cant get the heater to blow hot.
So this am, I took the old sensor out and fitted the new one supplied with the expansion tank: fully expecting to get a face of coolant!
But no- swapped them over dry as a bone? Reconnected and there is still a level warning light
So- aside the point I clearly have an air pocket somewhere preventing the heating to work- WTF is with the level sensor and expansion tank??
Stuart
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- patriot66
Hi Stu. Have you got the front of the car raised when bleeding ? I always have the front of mine on ramps or axle stands when I bleed it and never had an issue
Onlinebigwinn
Hi Si!
Yes all raised up
Going to give it another blast this afternoon
Only difference was 5L out but about 5.5L in?
Why is no coolant pouring out when I take the level sensor out though? I can’t get my head around that?
Level is high in the expansion tank? Is it possible I’ve got an air pocket in there?
Yes all raised up
EWS Delete PM me
EWS Delete PM me
- enuff_zed
Hi Stuart,
Ratcatcher cut up my old one. The sensor sits in an outer pocket. This is surrounded by a float with a magnet in it that actuates the reed switch in the sensor.
This float moves in its own chamber which is only about 1/4 of the height of the tank, so it only starts to move when the coolant is very low.
The float that pops out the top is a visual guide only. This only goes down to about 2/3 of the tank level. In other words, if your pop up float bottoms out, you still could have 1/3 tank of coolant in there.
I always assumed the pop up float activated the switch when it dropped right down, but the two are completely segregated.
Chop up your old tank, it's quite complex inside.
Onlinebigwinn
Wow!!
Off to get the Dremel to investigate
Cheers!!!
Cheers!!!
EWS Delete PM me
EWS Delete PM me
- enuff_zed
It seems a real piece of German over-engineering. Shame the plastic didn't live up to the design ethos.
Onlinebigwinn
EWS Delete PM me
EWS Delete PM me
Well, if my situation turns out to be an air lock of some sort, I believe M54 is a b*stard of a thing when it comes to draining and replacing the coolant. I've noticed something similar when I changed the exp. tank (I also used the old sensor): the heater was mildly cool on passenger side but hot on the driver's side. I had to make sure I got all the air out (which was not a quick ordeal) and add back some deionised water for the heater to even out. Even then, as you've seen on my other thread, I may have had a persistent air lock in the system. I wish I had a Z4 with an electric water pump to be honest...bigwinn wrote: ↑Wed Oct 27, 2021 10:49 am Morning all
Stuart
Onlinebigwinn
To be fair this is the first time I’ve had an issue bleeding- my own fault as I had the front up on axle stands as opposed to ramps-
EWS Delete PM me
EWS Delete PM me
- Chris_D
I've had an ongoing issue with my heating which I'm putting down to an air pocket trapped in the coolant loop.
I either get hot air or cold with not much temp regulation possible in between.
Need to try yet another bleed / top up at some point...
- enuff_zed
Did you get a chance to check out that expansion tank construction?
Onlinebigwinn
Still saved in the pile of stuff to do!
EWS Delete PM me
EWS Delete PM me
