Ghost in the engine?
OnlineMikeyH
Thank you patriot66, I’m afraid that is a beyond my skill. But from your photo it definitely looks like one or more of those.
- Z4Mariner
MikeyH -
Patriot66 mentions a key thing for your testing: The WD40/GT85 might not get past the pulley dust covers very easily, so remove if possible.
Another way to test is to remove the belt and spin idler pulley (if present) and the tensioner pulley by hand - if they spin freely, there's not enough grease, and if they wobble the bearing is finished. A common issue for many older BMW's - the plastic pulleys are not always replaced when the belt is changed out .
Z4Mariner
Minnesota, USA
2006 Z4 Coupe 3.0Si, Montego Blue, MT
Minnesota, USA
- paddy wright
Just to be sure you checked the right pipe for the split you did check the one circled below, it comes off the intake boot in to the engine from the air box, known to split?
- 06015124-75AE-4040-BE9A-7651E3958658.jpeg (35.5 KiB) Viewed 396 times
OnlineMikeyH
Thank you z4 mariner, it’s looking more like a job for the garage. PaddyWright, that’s not the one I’ve been looking at, it was a bigger one. I will have a look later. Many thanks for all your help guys
- paddy wright
Check this tread to show you where the split will be and if so how to swop over for a new one viewtopic.php?f=3&t=5592&p=1037799#p1037799
OnlineMikeyH
Thank you paddy wright, I have looked and it is the one I've been looking at. I was hopeful there.
OnlineMikeyH
Update. I thought I ought to tell what this was on this thread, Last week I removed a metal scoop thing from behind my right hand grill as it was rusting and looked nasty. Noise gone. Car sounds so much nicer now.
