Evening all
I have the start of some rust appearing on the top edge of the horizontal joint between the rear wing and the lower panel.
Before I start, had anyone any advice about removing the lower panel
Thanks.
Rust Issue
- Benderloch
Rust Issue
E86 Silver Grey Red leather, Piano Black trim.
Rust Issue
The Rust will be in the Upper wing ......at both forward and behind the back wheel, probably best to take the Wing off to de-rust, as it normally starts from behind.Will post a pic in the morning of a recently removed Panel with same symptoms.
The Lower panel has a series of plastic clips holding it on ,If you look underneath the car and in the door opening.
- Swiftly
Rust Issue
When I took mine off a couple of years ago, I found it's best to have some spare plastic rivets since they can break, flea bay is a good place to start. Also there is a body nut and a screw that you will also have to undo, part numbers 9 and 7
https://www.realoem.com/bmw/enUS/showpa ... Id=51_4862
Here's a link which should help you with the removing and fitting the side skirts which should be a quick and simple job
viewtopic.php?f=2&t=25105
- Benderloch
Rust Issue
Thanks for the link. I searched high a low for something like this.
Rust Issue
As promised ..from a E85
- 0C393C9A-2677-4CA0-9702-2B1A03810DCC.jpeg (75.07 KiB) Viewed 1059 times
- 86F51CB7-F611-45C5-ADE9-68C81BA5733D.jpeg (80.49 KiB) Viewed 1059 times
- 30A105AD-C102-4F74-A3D4-F89F8C922F76.jpeg (68.97 KiB) Viewed 1059 times
- Benderloch
Rust Issue
Thanks for the photos, As you say the wing needs to come off to sort this out properly
Rust Issue
To sort is it just a matter of taking it down to bare metal and treating with hammerite or similar?
Ratty 03 sterling silver project/daily
