Potential new e89 35is - Are these things normal?
Hi all,
I'm looking to get an e89 35is (had a 2.0 e85 years ago and loved it) and have seen a potentially perfect car with the spec that I'm after and fairly low mileage (49k for a 2011 model). A couple of things that have put doubt in my mind are:
- Tyres - there are different tyres on each corner. They seem in good quality (it's from a well rated garage) but is this an issue/potential problem?
- Condensation in both headlights. They said it had had a wash that morning so could have been that, but it's this a sign of something more sinister or easy to resolve?
- Air Con - this wasn't blowing cold and the garage said they can regas it, but could this be something else?
My husband plugged in his odb scanner and there were no issues and all electrics seen to work. We tested the roof which worked fine and there weren't any judders and weird engine concerns.
What are your thoughts?
- Scubaregs
Buying from a garage? 4 new matching tyres and regas as condition of sale. Condensation probably just due to washing but to be noted. If regas fails then aircon repair by garage as condition of sale. Get it all in writing if you buy.
- mr.tourette
tyres are odd.. who would do that.? if everything else checks out Id be asking for a matched set in the deal
condensation in headlights not uncommon in z4, still the just washed excuse doesnt wash it will need addressing properly
Aircon could just be a regas job.. again not uncommon but it could also be the aircon expansion tank leaking so that would also want a bit of investigation... in all honesty it doesn't sound like a pampered car.. the tyre situation alone would have me worried as it reeks of being run on a shoestring budget
OnlineB21
Hello..having just bought a 35is and studied them for a long time there are a few things to look for in the short term, but a pile of things that will occur at some time, if you keep the car that long.
So first thing is to try and get detailed maintenance records if all possible..
To answer your short term questions.
Headlight fogging after washing on an E89 is 'normal' and referred to in the owner manual..obviously it can be chronic but its unsual..
Never, ever mix tyres on a high performance car for all sorts of reasons, that's a generalisation but not bad view, there are exceptions but on a 35is the handling is wayward enough without causing further issues.
The aircon is normally very reliable, if there are no fault codes then imaybe its leaked out but why should it leak out?
The 35is (and its sister 35i) does have a whole series of expensive issues which probably are best covered with a very decent warranty.
Obviously if these issues have been addressed then it maybe is ok, hence the question reference maintenance records..
So the list of things that will go wrong..often from 50k miles onwards but not necessarily so are:
High pressure fuel pump
Leaking fuel injectors
Rattly wastegates on turbos
Failing turbos
Failing / leaking adaptive dampers
Then there are plugs/coils/coking up, leaking cam box seals issues as well but not as expensive..
Just be wary, if you have deep pockets then its fine, if you have already stretched yourself caveat emperor..
On mine, for example, weird things were only on expensive injector replaced out of a bank of 3 which is prohibited, just found that the rear electronic brake caliper is damaged, quite how, a coil failed a few weeks after I bought it..
A 23i/30i/18/20/28i are lower risk cars..
Failing turbos
A very modified Atacama Yellow 35is
Thanks for the responses, the garage did say they had swapped one of the tyres, but the other three were on the car.
- Scubaregs
The tyres should be non negotiable.
- Ole gits rule
Tyres and working aircon as part of the deal - if they don't want to do it walk away there are others out there
M4 Vert in Yas Marina Blue
- Chippie
When I bought mine it had a matching pair of tyres on the front and an odd set on the rear, apparently it had had to have a rear replaced due to a puncture, due to the odd pair on the rear the handling when flooring the accelerator was unsettling to say the least, and put my heart in my throat, after fitting a new full set of Michelin ps4s’s it transformed the handling, so if you buy this car make sure you get a decent set of matching tyres at least on the rear, for reference a full set of ps4s’s are around £700
E89 35is space grey Kansas coral red leather
Tyres as has been said is a big no no. Matching set is a must. Either you budget for replacing or walk away.
The aircon should not need a regass unless there is a leak! So assume there is a leak that will need to be addressed.
This is where a warrantee would be useful.
What’s your budget for a 35is?
Why would anyone put odd tyres on a performance car? To me it's a possible sign that the car has not been looked after as it should.
Personally I would walk away, there are better examples on this forum from time to time.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Stevo1987
Even in todays market should find something for 20k I would have thought.
2014 Z4 e89 35is in mineral grey.
2012 Audi TTS in Ibis white.
I would certainly walk away from that particular car, for all the reasons stated above. They "dealership" are obviously still expecting strong money for this car, but they cannot be bothered to prep it correctly before offering it for sale?
Aircon needing a "regas" is bollocks — as stated above, it has leaked out. That means there is a leak, and that leak needs to be found and rectified before any "regas". Could be a simple joint leak (unlikely) but also could be a condenser leak (expensive) an evaporator leak (more expensive), or even a faulty compressor (mega expensive!).
If you're going to spend that money, give it a bit of time and find a good, pampered and cherished car.
Up to you.
Up to you.
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
- Marcoose
4 different tyres? I’ve never heard of that. No way. Condensation? Thanks but no thanks. For that kind of money, it’s worth waiting.
And for the love of God, do not put an M badge on the 35is.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
As others have mentioned, if you do go ahead with the purchase insist on 4 matching new tyres. I have noticed the headlights fogging up sometimes after a jet wash but it clears up pretty quick, so if after a day the condensation is still there then there is some other issue. Again as others have mentioned air con could be a simple re-gas or a leak somewhere.
