Hello I would like to ask a quick question. What is the right size for BMW Z4M for Michelin Supersport with standard wheels?
255/40/18
225/45/18
or
255/45/18
225/45/18
Michellin Supersport PSS correct size
- buzyg
First option is correct - which keeps the front to rear tyre ratio the same despite the wider rear tyre.
If you did the 2nd option, you'd end up with a rear tyre profile that was about 1cm taller than the front:
- 225/45r18 = 660mm diameter
- 255/40r18 = 661mm diameter
- 255/45r18 = 687mm diameter
- 265/40r18 = 669mm diameter
- Mr Tidy
Yes, the first option is factory sizes.
But when I bought new tyres in April I went with your 2nd option for a bit more sidewall and haven't had any issues - plus they fill the wheelarches a bit more!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Perfect. Thank you guys for your immediate response.
- Argenta
I do believe the answer was much closer than this forum; either on the note by your driver door or in the owners manual.
Assuming the OP was with the car!
The internet is with you 90% of the time even when you're in another county/country without the car!
- Argenta
