A different roof problem
- enuff_zed
Hi all,
On Rob's advice I have purchased what I hope is the correct Terminal 30 Relay.
I'll swap this out first and see if it fixes it. Being an intermittent issue I may have to wait a while.
Currently convinced it's not a wiring issue as the correlation between engine running/not running is exactly the same every time.
Big question.
Anyone know exactly where this relay is fitted?
Number5, the fact you're very quiet is worrying me.
EDIT:
If it helps anyone to help me, I should also say that when the roof won't work with the engine running I turn it off and it works.
Thereafter it will work fine with the engine running. Almost like a contact is sticking.
Big question.
EDIT:
- Number5
Yes. I’m quiet as Rob has confused me with his E89 relay board, or maybe I’m reading the situation wrong
Generally I’d first swap out the roof ECU (c£40 on eBay if you can’t borrow one off someone local to try first) as that is a simple task to swap and requires no programming.
Secondly, I’d suspect the sensor loom could be giving you an intermittent fault.
Thirdly, as it’s the most complicated swap, is to look at the GM5 unit. Maybe it’s a signal issue, either speed or voltage related.
However, it’s not a fault I’ve come across myself.
When it refuses to move/work, do you get any LEDs on the roof switches ?
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- enuff_zed
Cheers Alan,Number5 wrote: ↑Thu Oct 21, 2021 8:50 pm Yes. I’m quiet as Rob has confused me with his E89 relay board, or maybe I’m reading the situation wrong
The relay may have been a red herring it seems? I'll have a good search at the weekend.
Then it'll be ECU.
Sensor loom? Can't rule it out, but this issue of it only failing wit the engine running, then working fine as soon as you turn it off doesn't seem to tally with that?
When it won't work I get nothing, like I'm pressing a button not connected to anything?
I too am at a loss so far.
If I can't locate the relay I'll send Rob the bill and look for an ecu.
- Smartbear
No guarantees with Smartbear diagnostic advice but your issue does sound different from most e85 roof faults & i know this relay could potentially be the cause, pics were of my car but the e85 uses similar technology so worth trying as they’re not that expensive.enuff_zed wrote: ↑Thu Oct 21, 2021 9:41 pmCheers Alan,Number5 wrote: ↑Thu Oct 21, 2021 8:50 pm Yes. I’m quiet as Rob has confused me with his E89 relay board, or maybe I’m reading the situation wrong
Then it'll be ECU.
If it doesn’t work send it to my receptionist @ Smartbear Towers
e85 3.0si sold
- enuff_zed
Hi Rob,Smartbear wrote: ↑Thu Oct 21, 2021 11:30 pmNo guarantees with Smartbear diagnostic advice but your issue does sound different from most e85 roof faults & i know this relay could potentially be the cause, pics were of my car but the e85 uses similar technology so worth trying as they’re not that expensive.enuff_zed wrote: ↑Thu Oct 21, 2021 9:41 pmCheers Alan,Number5 wrote: ↑Thu Oct 21, 2021 8:50 pm Yes. I’m quiet as Rob has confused me with his E89 relay board, or maybe I’m reading the situation wrong
Then it'll be ECU.
The issue is I can't find it!
According to realoem there are two lilac roof relays behind the glove box.
The only other possible option I can see is the blue DME relay in the engine bay, but I'm loath to mess with that on a whim.
Online
Martin …you need these
Online
Will post today
- enuff_zed
Barry, you are a star!
Let me know how much and I'll fire it over now.
Hopefully you still have my address?
- bigwinn
V difficult to find you need to be head down in the footwell, looking behind the fuse box up toward the gm5 moduleenuff_zed wrote: ↑Fri Oct 22, 2021 8:00 amHi Rob,Smartbear wrote: ↑Thu Oct 21, 2021 11:30 pmNo guarantees with Smartbear diagnostic advice but your issue does sound different from most e85 roof faults & i know this relay could potentially be the cause, pics were of my car but the e85 uses similar technology so worth trying as they’re not that expensive.enuff_zed wrote: ↑Thu Oct 21, 2021 9:41 pm
Cheers Alan,
Then it'll be ECU.
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- enuff_zed
Yes Stuart, I know the roof relays are there, and Barry can get me those to swap out.bigwinn wrote: ↑Fri Oct 22, 2021 9:24 amV difficult to find you need to be head down in the footwell, looking behind the fuse box up toward the gm5 moduleenuff_zed wrote: ↑Fri Oct 22, 2021 8:00 amHi Rob,Smartbear wrote: ↑Thu Oct 21, 2021 11:30 pm
It's the actual existence of the mythical Terminal 30 relay I'm doubting a little now?
No sign of it on realoem that I can find?
(Bearing in mind I'm engines and airframes, not electrickery)
- enuff_zed
Number5, there are several different part numbers for the roof module.
Realoem does say they are all compatible, but I thought I'd just check with you first.
Plan is to swap the two relays and the module at the same time. No messing about, as it's an intermittent fault, and if I'm having to wait ages to confirm it, I don't want to do that three times over.
To confirm, the car is an 04-plate 2.2i.
Cheers.
Cheers.
Online
Hi Martin …Relays posted 1st Class this morning
- enuff_zed
Cheers Barry. Paypal actioned. Let me if there's not enough.
- Number5
I understand from a time saving point of view, but I’d only want to make one change at a time and identify the faulty part.enuff_zed wrote: ↑Fri Oct 22, 2021 1:15 pm Number5, there are several different part numbers for the roof module.
Cheers.
If you PM me your address I’ll post you a roof module to try. If it solves it we’ll sort something out, if not, just post it back to me.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- enuff_zed
Aye, been thinking more on that and you're probably right.Number5 wrote: ↑Fri Oct 22, 2021 5:50 pmI understand from a time saving point of view, but I’d only want to make one change at a time and identify the faulty part.enuff_zed wrote: ↑Fri Oct 22, 2021 1:15 pm Number5, there are several different part numbers for the roof module.
Cheers.
That's a kind offer Alan, thank you. (Gotta love this forum)
PM inbound.
