Well that sparked a few interesting views !!!! I agree that it can improve the visual appearance and stance but Im one of those who likes his cake and eats it wherever possible!
So it was impossible to get the correct offset for the fronts so I've compensated with adding a 5mm spacer (hardly seemed worth it but hey) and the rears are standard. So do we think then adding an additional 10mm each side to the rear and replacing the 5mm with 15mm on the fronts do we think Im going to see improvements or just more stress on the suspension and worse handling!
Benefits of wheel spacers????
- mkinternet
E89 - 3.0i Auto 2010
Bilstein B12 Pro Kit
Wiechers Front Strut Brace
19” MAK LUFT Wheels
H&R Anti Roll Bars (Front and Rear)
Royals Steering Wheel
35i Brake Upgrade
Stage 1 Remap
19” MAK LUFT Wheels
35i Brake Upgrade
Stage 1 Remap
OnlineB21
Personally on the E89 I'd keep the front offset close to stock..15mm IMHO is too far!mkinternet wrote: ↑Thu Oct 14, 2021 3:51 pm Well that sparked a few interesting views !!!! I agree that it can improve the visual appearance and stance but Im one of those who likes his cake and its it wherever possible!
- enuff_zed
Just double checked and need to make a correction.
I have 15mm on the rear and nothing on the front.
- LeeZ4MR
I have 25mm spacers all round on my 370Z Roadster. It definitely improves the stance and I like how the wheels sit flush with the arches. The wheels look quite lost in the arches without them I reckon.
I quite fancy some on the M4 as well, because the wheels sit in the arches a bit on that as well.
Added a photo to show how it sits with 25mm all round.
Current...BMW F82 M4 Coupe 2018
370Z Roadster 2011
Merc GLE400d 2022
Caterham 7 2002
Previous...
640d 2012
330i 2006
Z4MR 2006
E92 M3 2009
X5 4.8iS 2004
TVR Cerbera 4.5
370Z Roadster 2011
Merc GLE400d 2022
Caterham 7 2002
Previous...
640d 2012
330i 2006
Z4MR 2006
E92 M3 2009
X5 4.8iS 2004
TVR Cerbera 4.5
- Chris_D
20mm on the back of mine, nothing at the front and find it a perfect stance/aesthetic.
No detrimental effect on handling and not worried in the slightest about additional stresses on suspension components. They will be absolutely negligible at worst considering the mechanical coupling and dimensional increases involved.
- TomK
Yes, I understand what your point was and no doubt it is true to some extent, I was just trying to say it's a bit of a non-event when kept within relatively normal boundaries (50mm is not what most people would consider to be normal). Can you show me an instance for example on this forum of the no doubt many hundreds if not thousands of people who have run spacers and suffered a resultant mechanical failure?sars wrote: ↑Wed Oct 13, 2021 10:51 pm TomK, are you stating that it’s okay for him to add spacers to widen the track, how thick should he go? 5, 10, 15 or perhaps 50mm is okay. Your argument that BMW does it so it’s okay, which it is for them because someone at BMW will have calculated it all out, have you?
My point was and remains so, that lowering the offset using spacers increases the stress on steering/suspension components, this is an indisputable fact
