Atacama Yellow 35is build thread
B21
Post by B21 » Wed Oct 13, 2021 7:32 pm
R.E92 wrote: Wed Oct 13, 2021 7:26 pm
B21 wrote: Wed Oct 13, 2021 7:04 pm Hi R.E92..when you say 'suction filter on the side'..so there is one in the sump and one elsewhere for the DCt?
Yes, 2 filters.
Here's a list of parts that might be useful for the DCT service:
https://www.fcpeuro.com/BMW-parts/Z4/Tr ... 0&d=788&v=
:thumbsup:
I'll get round to that over the winter..
A very modified Atacama Yellow 35is :thumbsup:
tiglon
Post by tiglon » Sat Oct 16, 2021 11:15 am
B21 wrote: Wed Oct 06, 2021 11:25 pm And yes on full song the 35is makes a great noise…pity gutting the back boxes means a real drone in the cabin when sat at a steady 60-70 :tumbleweed:
Since reading this I've been paying attention to noise at motorway speeds, because this wasn't something that I thought rang true with my car. When cruising at 60-80 in mine, all you can hear is wind and tyres - the exhaust only becomes audible when you put your foot down or reach 3,000 revs. I wonder if someone has previously done the gold tee mod on your exhaust and the valve is constantly open? I'm pretty sure that in mine the valve is closed until you hit 3,000 revs which is 90mph in 7th.
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
R.E92
Post by R.E92 » Sat Oct 16, 2021 11:32 am
The 35is exhaust is great on a stock car but it becomes a pain when you start to mod. It's the same problem with the 335i coupe.
If you add catless downpipes to the 35is it drones because of the lack of silencing. My 35i is fine, no drone at any RPM but my 335i has the louder BMW exhaust with it being the coupe and it'll drone at 3k rpm with the catless downpipes.
B21
Post by B21 » Sat Oct 16, 2021 12:21 pm
tiglon wrote: Sat Oct 16, 2021 11:15 am
Hi depends where you live..round here we are constantly going up slight inclines so say at 50-60 you are using a bit of throttle and low revs..that’s when it really drones..
Given the stock nature of the car and minimal attention to anything..like one index 12 injector with 5 index 9 injectors and minimal servicing I doubt that the T mod was done…🙈
B21
Post by B21 » Sat Oct 16, 2021 12:22 pm
R.E92 wrote: Sat Oct 16, 2021 11:32 am The 35is exhaust is great on a stock car but it becomes a pain when you start to mod. It's the same problem with the 335i coupe.
Oh dear..looks like I’m in for more droning…
Don’t really want to swap out the rest of the exhaust…
Any creative solutions?
R.E92
Post by R.E92 » Sat Oct 16, 2021 2:13 pm
I've seen people getting exhaust shops to fit extra resonators in the US.
It's easy to see if the exhaust mod has been done. The flap should be closed during cold start so you can visually check.
B21
Post by B21 » Sat Oct 16, 2021 2:45 pm
R.E92 wrote: Sat Oct 16, 2021 2:13 pm I've seen people getting exhaust shops to fit extra resonators in the US.
OK thnx..so on the 35 the exhaust flap is closed during start-up? On the N20 its the opposite.. :tumbleweed:
B21
Post by B21 » Tue Oct 19, 2021 4:49 pm
So one Volvo XC70 full of boxes, 3 E89s, the swap and upgrade programs begin..
One broken rear stock spring on the AY 20i found so far..
2021-10-19 14.21.39.jpg (217.79 KiB) Viewed 1006 times
Ole gits rule
Post by Ole gits rule » Tue Oct 19, 2021 4:52 pm
Boy oh boy -looks like a load of work ongoing
M4 Vert in Yas Marina Blue
B21
Post by B21 » Tue Oct 19, 2021 5:26 pm
Ole gits rule wrote: Tue Oct 19, 2021 4:52 pm Boy oh boy -looks like a load of work ongoing
change plan.jpg (147.64 KiB) Viewed 993 times
Ole gits rule
Post by Ole gits rule » Wed Oct 20, 2021 9:04 am
You need a programme manager to get that sorted
B21
Post by B21 » Wed Oct 20, 2021 1:48 pm
Ole gits rule wrote: Wed Oct 20, 2021 9:04 am You need a programme manager to get that sorted
I used to be a project/ program manager in previous lives..in fact was the CEO of a Program Management software company 2000-2004… :tumbleweed:
Sadly my first port of call garage couldn’t even comprehend a simple spreadsheet 🙈
Stevo1987
Post by Stevo1987 » Wed Oct 20, 2021 2:00 pm
B21 wrote: Wed Oct 20, 2021 1:48 pm
It is scrum master now old fogies..... :poke:
2014 Z4 e89 35is in mineral grey.
2012 Audi TTS in Ibis white.
R.E92
Post by R.E92 » Wed Oct 20, 2021 2:18 pm
B21 wrote: Tue Oct 19, 2021 5:26 pm
That's a very ambitious work order. Are you going to try reuse existing fixings and hardware or have you ordered fresh parts for that?
The idea is to take any 2.0 specific mods off your old yellow Z4 and put it on the orange Z4, then transfer any upgrades that'll fit the new yellow 3.0 Z4 and use the old 3.0 parts on the orange 2.0 and then return the old yellow one to stock before sale?
B21
Post by B21 » Wed Oct 20, 2021 5:44 pm
R.E92 wrote: Wed Oct 20, 2021 2:18 pm
Hi…yes it’s a lot of work although logically there are some work threads which should allow an efficient execution of the program.
I’ve got a very big box of bushes, seals, clips, hoses etc so should be able to cover most things..
The garage has access to an hourly parts delivery service so hopefully we won’t get held up for want of a seal etc..
I’m impressed with the chap I’m using..he’s very well referred to by both the other garages I routinely use..
He’s multi skilled so most things shouldn’t defeat him, and his approach to a replacement diff which has had its main shaft nut incorrectly fitted indicates to me he’s not going to skimp especially as I’ve told him not to re-use / bodge anything..
The migration / mix program is more complex than you suggested so the 20i will end up as a super 28i + with lots of cosmetic goodies, steering parts and audio bits that were better than fitted.
So the 20i will still be a 300 bhp+ 450nm 28i version with cosmetic and handling trimmings …
Those parts that don’t fit the 35is and aren’t going on the VO 20i will be ebayed / forum-ide
