Yes I decided to be confident …I guess after several s/w releases and the latest hardware it hopefully is now stable and debugged..Silverstar wrote: ↑Sun Feb 19, 2023 7:51 pm Speaker install is looking good as is the carbon fibre console the MMI box placement is neat but will be a pain to get to in the future if you ever need to.
Atacama Yellow 35is build thread
- B21
We choose to go to on with this endeavour at this time and do the other things, not because they are easy, but because they are hard..
- B21
Been putting off mounting the new carbon fibre wrapped trim to the original panels…( have to swap them across to retain the impulse alacantra trim.
So drilled out the black plastic rivets with an 8mm drill..the old trim presses out then fitted the new C/F parts and used the glue gun to hold in place..
Nice result..
Nice result..
- B4938E44-2028-4313-85D8-496C1530399B.jpeg (276.35 KiB) Viewed 911 times
- F33AF9B5-FE24-446A-9216-2D6C215731D0.jpeg (262.71 KiB) Viewed 911 times
- CABE4E99-06CC-421A-8C48-3AD5E2EA710E.jpeg (226.86 KiB) Viewed 911 times
- BE4B2572-E3D1-4953-B106-3F294CD6A8E1.jpeg (213.03 KiB) Viewed 911 times
- D3F32D4F-A0DE-4C61-A860-8D983B65BAA4.jpeg (238.46 KiB) Viewed 911 times
- C4A9CA0E-441D-421A-BB2D-DDBD0520D291.jpeg (277.05 KiB) Viewed 911 times
- 8D30CB48-9F08-4C46-8BB3-9FEB81552B61.jpeg (278.7 KiB) Viewed 911 times
- 50E39977-BCAC-4283-AE93-2E04DF8123AB.jpeg (289.27 KiB) Viewed 911 times
- Jey
Very nice
E89 - s23i 2010 Saphire Black
18 inch alloys for comfort - Idrive, cruise, and lots of smiles per mile...
- axelleveau
That mix is very sexy!
Gone - Ford Ka MK2 Petrol - Black
Will hang around to carry materials/people and in emergency - Ford Fiesta MK7 1.0 Ecoboost - Black, white rally rims, white decals, remapped
Now - Z4 Coupe - Montego Blue: Here
- B21
When I tried to get the steering geometry set up we found that the toe in couldn’t be set to perfection due to limitations in adjustment of the stock rear trailing arm to chassis brackets.
In addition they observed that the trailing arm bushes fitted only a year earlier were showing signs of wear…
The E89 rear suspension is a complete copy of the E85/86 except that certain dimensions are altered as a result of track width changes.
The E85 boys have been changing their RTABs for a long time with all sorts of versions being used such stock, polyurethane and even roller bearings.
The issue for the E89 as well is that the whole rear wheel geometry and stability rests on the integrity of the bush and its relationship to the arm and bracket.
The problem is that with 400 BHP tugging at the bushes they deform under load and wear..in both cases the toe in fa tor changes..going to toe out..analogous to dynamic and unmanageable rear wheel steering.
To get round these issues I’ve bought some chunkier RTAB mounting plates that bolt to the chassis and have much greater adjustability.
To get round the distortion that happens to the RTAB there are various solutions..needle / roller bearings, polyurethane bushes and in this case a much uprated rubber based bush but with a focus on stability whilst still avoiding NVH induced issues.
Hardrace make these bushes for a wide variety of cars and other suspension related bushes..as well as needle roller solutions if you can cope with NVH.
I’ve got the bushes for the other linkages , 2 per side.
Since all these bushes during their installation process will affect the geometry I plan to get these done by the shop that then does the geometry adjustment..
Pictures show the stock bushes alongside their uprated cousins..
This set cost around £300 so not a cheap solution plus another £100 ish for the chunky brackets..
- 8D53C00C-2483-4683-BF06-8C5D0EA90E0E.jpeg (200.46 KiB) Viewed 843 times
- DAB8F9A8-C7C2-4E7E-833E-6845434BAB13.jpeg (157.91 KiB) Viewed 843 times
- CBAF74BF-DD9E-47DE-B4D8-9E96C7522BF1.jpeg (178.4 KiB) Viewed 843 times
- 6D54EFC8-9F72-4F18-A057-DE3AA80FBC9D.jpeg (172.88 KiB) Viewed 843 times
- B1C417CB-4218-419A-9B8D-BE54D533CA9E.jpeg (189.03 KiB) Viewed 843 times
- 095745AA-2D25-4828-A299-F36E55502DF6.jpeg (219.06 KiB) Viewed 843 times
- D450B5A4-8D96-419D-B1BF-AE69A4E84BD5.jpeg (201.78 KiB) Viewed 843 times
- 32078158-8D70-489E-8D6D-6A1D93C6852A.jpeg (151.91 KiB) Viewed 843 times
- Jey
B21, this is a very high level of devotion you’re showing to your car, obsessive some might say. Or impressive, I go with the latter, do you track this car or intend to?
- B21
Yes it’s OCD….
No I don’t track my car..if that was the focus you would do somethings differently..more camber, lower ride height, more damping, bigger brakes, stiffer ARB settings etc
The focus is on ‘hooning’..that is wandering at high speed across Scotland’s bumpy, often bendy, usually narrow roads..the focus is on high speed control, stability, large margins of grip and ability to cope with sudden, unforeseen circumstances…
- Jey
Hooning around the twisties in Scotland sounds good, I’d need a car the where the handling far exceeds my ability to keep me in one piece
- B21
Yes exactly, unfortunately the N54 Zeds have an engine whose power and mass overwhelm what is otherwise quite a reasonable chassis…
Hence my mods ..
- B21
There was a burst of activity a couple of years ago headed by Silverstar and Nitrix in using genuine carbon fibre to over lay on the E89 interior trim areas.
I bought from Silverstar a set of interior trims and some panels that had been carbon fibre’ d and then epoxy resin coated..
For various reasons they languished in my goodies cupboard…
This winter I decided to fit them, then as I pondered I realised that leaving the door handle trim in its original yukkie dark brown trim would be an affront to tactile and visual tastes..
Therefore I contacted Silverstar with a fire to getting these done..pleased to say he’s still in the market for doing them.
These arrived yesterday., just unwrapped and very beautiful.
So the good bits are..
Despite quite thick layers of epoxy the trim and controls reassemble without any issues
The photos don’t do justice to the lustre and depth
A lovely tactile feel to the finish
I had the gear gaiter re-finished by Royal Steering Wheels to suit them plus the Royal Steering wheel re-furb
Things to consider are
Unless you have a spare trim set there is a 2 to 3 week turnaround / down time
Costs..Silverstar quotes £500 for a complete set of your trim being processed..plus p+p..which given the time and quality I honk is very reasonable for the result…especially if you are a crack handed muppet
I think the cleaning of the surfaces will need to be done very carefully to avoid scratches in the epoxy
Well pleased and a big thanks to Silverstar
Unfortunately I’m limited to the house following a major eye op but hopefully in 4 to 6 weeks time I’ll be able to fit them.
- 32E9C428-751A-446A-820C-11A5A1B82479.jpeg (130.21 KiB) Viewed 690 times
- B1BCF143-3DCC-4A6C-A28A-1AED381CF013.jpeg (151.22 KiB) Viewed 690 times
- AE34E2C0-B79B-489D-8A89-1B7844461BF3.jpeg (160.69 KiB) Viewed 690 times
- 42C589C3-0664-44AE-A160-CE4666257FAB.jpeg (193.7 KiB) Viewed 690 times
- 402309EA-0CE5-4EC9-AA2F-01B21467205F.jpeg (173.76 KiB) Viewed 690 times
- D4BCBBAE-08A7-4E40-84A3-CC2833B942D7.jpeg (176.04 KiB) Viewed 690 times
- B21
Thanks to Mark. 3 versions of my Garmin Mini 2 pedestal arrived…when I can get back in the garage I’ll give these babies a go
3D printing is a wonderful thing …going to look very professional..compared to a bent metal bracket.
- 4AB2F0CB-5B5F-41F8-853F-A5AC6FA18C1C.jpeg (192.94 KiB) Viewed 646 times
- 470B6F16-4E19-4276-A9FA-D896A28757B4.jpeg (156.13 KiB) Viewed 646 times
- B21
Test fit of rear facing camera looks good ..
- C955552B-DE0C-4A71-BD6E-F68394283186.jpeg (189.89 KiB) Viewed 614 times
- 66EA30E2-B5FC-4959-B0FA-8911BE6F5476.jpeg (152.1 KiB) Viewed 614 times
- 8D29A9C4-84CA-47FA-B56B-D45C08D19541.jpeg (129.29 KiB) Viewed 614 times
- peeblezZ4
Looks great!
Current - '12 Space Grey 640i Auto SE Convertible
Previous
'11 E89 Sapphire Black 35i auto M-Sport Sold August 2023
'13 E89 Valencia Orange 2.0 Auto M-Sport (Sold on another whim)
'03 E85 Titanium Silver 2.5i Auto (Sold on a whim)
Previous
- B21
Another B21 shaped hole I dug myself into.
I fitted a Wagner Evo 1 FMIC to replace the stock FMIC on my 20i when I remapped it past 300bhp.
It turns out that the 18i/20i/28i FMIC is the same as the 35i/35is FMIC.
Prior to selling the car I re-installed the OE FMIC and transfered the Wagner Evo 1 FMIC to the 35is..all well and with that went onto record 400 bhp on my trusty dyno.
Fast forward on to the uprated TTE500 turbo upgrade plan..whih called for uprated inlet /outlet plumbing from 1.75" to 2"
Sudden dawning that both the relative sizing and the type of connectors was going to be a problem.
The OE connectors to the OE FMIC are push in and circlip..the aftermarket turbos, the outlet pipes and charge pipes are all push over with hose clamps.
I therefore was left with an imponderable when we came to fit said plumbing..how and if I could connect the Evo1 with OE style connectors to the new larger 2" slip over plumbing and uprated VTT turbo outlet pipes and new VSRF charge pipe.
Given that I'm using a local garage's 4 post lift and helper I didn't want to get stuck with an issue that either couldn't be resolved or would take time.
The issue is the dissimilar sizes of the external diameter of the Evo 1 FMIC and the plumbing around it..about 12-15 mm difference and the need also for flexible couplings and high temperature (greater than 150c) and high pressures (more than 2 bar) required.
In the end I just opened up the wallet and bought an Evo 2 which is designed for the job..so all plumbing lines up, they supply the correct hoses and voila..problem solved..
There is a small performance advantage of the Evo 2 as a tube and fin construction vs the Evo 1 which bar and plate.
First world problems..
Pictures show relevant story and stock 35i FMIC for comparison.
- IMG_1694.jpeg (142.78 KiB) Viewed 551 times
- IMG_1693.jpeg (133.32 KiB) Viewed 551 times
- IMG_1692.jpeg (144.48 KiB) Viewed 551 times
- IMG_1691.jpeg (160.33 KiB) Viewed 551 times
- IMG_1690.jpeg (169.13 KiB) Viewed 551 times
- IMG_1689.jpeg (136.44 KiB) Viewed 551 times
- IMG_1688.jpeg (185.84 KiB) Viewed 551 times
- IMG_1686.jpeg (166.44 KiB) Viewed 551 times
- IMG_1685.jpeg (142.05 KiB) Viewed 551 times
- B21
After several weeks off from my eye op starting to get going in the garage..
Decided to play around with the MMI MOST box start up screen that can no longer be changed in the latest release and has the Mr 12 Volt splash screen.
So uploaded a 1280*480 splash screen of my own and also replaced the Mr 12 Volt Icon in the apps screen with a tasteful BMW logo..
Will start buttoning up the interior steadily now..
- IMG_7483.JPEG (170.06 KiB) Viewed 506 times
- IMG_7477.JPEG (165.33 KiB) Viewed 506 times
