Hi Si,
I guess I made it complicated for myself…
Law of unintended consequences plus try something different plus trying to address a wayward 35is..
So by buying the 437Ms you really need a 235 or 245 on the front and a 275 or 285 rears..being an E89 (or E85) you need to keep the rolling radius within about 1%.
On M2 etc they use a 35 profile but to get it to work within the constraints of the DSC the ‘best’ combo is 235/35 19 and 275/30 19 on the rear.
So it turns out that 275/30 19 is quite restrictive in terms of tyre choices.
With the mods at this stage I should end up at around 420 BHP and about 600nm.
Given that the handling of the 35is is quite wayward, I’ve hit it with a Quaife LSD, uprated ARBs, plus Ohlins and various M3 steering parts to try and tame it.
As part of taming it I wanted ‘the best’ tyres..
Many people rave about the Michelin Sport 4 and in a 275/30 19 you can only get it in a Sport 4S version.
The Sports Conti 6 is about to be obsoleted by the Sports Contact 7, but that is not yet available in a 275/30 19 size.
At the same time given I didn’t want to simply repeat the admittedly winning setup of the 20i I built I’d thought I’d try something different.
So that rules out the Goodyear Assy 5 and the Conti Sports Contact 5/5P/6
Frankly I wasn’t brave enough to try the new Bridgestone Sport..I see it has had overall very good reviews, maybe just not quite so good in the wet as others and open questions about predicted life.
So I went for the Michelin 4S.
I’d be very interested to see how you get on with the new Bridgestone Sports
So I guess we can compare notes..if and when Conti release the Sports 7 I may well try them as they should match if not exceed the 4S for my kind of driving.
Long ramble ..
