Water Pump - N52
AveZ4coop
Water Pump - N52
Post by AveZ4coop » Thu Oct 21, 2021 7:54 pm
Jack up right front corner, look underneath and it is easy to see what you need to do. Easy job if you have the correct socket fitting (E ? can't remember the exact size/number). 3 bolts, so takes less than an hour even if you take your time. :thumbsup:
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure :cry: (should have done it at 100k) :headbang:
