M2/M3/M4 (F8x) Brake Caliper Upgrade for Z4 M
- RvsBmw
Hi all,
Anyone have thoughts or experience with the swap from OEM calipers/rotors to M2/M3/M4 brake calipers and rotors?
I've to change the pads and rotors because the're done.
On the M3 e46 they its done before, but i havent seen it on the Z4 M e86/85.
Curious if:
- the brake balans is wrong, or not;
- It will fit with an e46 adapter but will fit on the z4, by my knowledge the use the same parts so it should .
Thanks for reply's with thoughts/experiences or advice !
Greetz
Curious if:
Greetz
- 152CD460-8CC3-4705-A996-36AEFBBEC56A.jpeg (108.04 KiB) Viewed 1203 times
Current: BMW Z4M Coupe '07 (one-off) | Midnight Blue Metallic | Syrah Blue Leather | OEM CSL's | Aero's
Gone: BMW Z4M Coupe '08 | Sapphire Black | Bicolour Silverstone Anthrazit | OEM CSL's | Aero's
- Beedub
its doable from a hardware point of view.....
what you need to do is find out the piston diameter so you can do the calculations to check the master cylinder is well matched.. if not you could end up with worse brakes than stock that are actually very good with the right hardware changes.
- RvsBmw
Dont want to be ended up with worse brakes..
Other wise will upgrade the brake lines, pads, cooling...
But if its a nice refresh with performance/looks, why not!
I've found the diameter of the fronts and rear.
Front:
OEM: 60mm;
M3 F8X front (4 pistons): 2x 36,5mm
M2C F8X front (6 pistons): 30/34/36mm
Rear:
OEM: 46mm
M3 F8X rear (2 pistons): 40mm
M2C F8x (4 pistons): 28/28mm
Anyone knows if it will work out, the f8x or the M2C kit?
- RedUn
Maybe a daft question but why not buy a bbk that's been designed for the car?
A full set of M2C brakes can't be that much cheaper?
I'd tend to think they'd be a better choice anyway as its probably a similar weight, chassis size etc
IMOLA Z4///MR
- Vanne
exactly what I was thinking...
Powered by Severn Tuning
- RvsBmw
Thanks for reply RedUn and Vanne.
I've read that a lot of people are quit happy with the me F8x brakes (not comp).
That ones go for cheap (around 2k for a set) and looks "original".
Perhaps it should be a relatively "cheap" upgrade and get much better brakes.
Indeed the M2C kit (shared with the M5 on some smal differences) is more expensive.
A set of M2C is going for 3k - 5k euro.
Compaired with BBK kit from brembo/stoptech/... is starting for 3k for fronts only.
Was looking around for different options.
Don't want to mess it up and ending up with less performance or dangerous situation.
I have just ordered the below. I think they will give a small upgrade in performance and look a lot better. My front are due a rebuild anyway so i thought i would give these a try.
https://freakyparts.co.uk/collections/b ... -brake-kit
2nd gear sideways
- RedUn
I'm sure the offset is slightly different on the front hub between the E46 and the zed, you may need modified brackets, keep an eye out for thatMatt.13 wrote: ↑Thu Oct 07, 2021 7:43 am I have just ordered the below. I think they will give a small upgrade in performance and look a lot better. My front are due a rebuild anyway so i thought i would give these a try.
IMOLA Z4///MR
- RvsBmw
Hi Matt,
Thanks for rreply.
Lookslike the Porsche 996 calipers if im right .
Did you bought for front or for front and rear?
I think this setup (all around) isnt in line with the brake bias, but im not sure..
They are megan r.s calipers. I think they are quite common and are used on alot of car tbh. Yer bias will shift a little forward. I have only ordered the front as they dont make a rear kit yet. Loads of info on m3 cutters about them. For £700 i dont think they are a bad option tbh
2nd gear sideways
Thanks. Ill have to wait and see if the brackets need modifying. Im hoping not.RedUn wrote: ↑Thu Oct 07, 2021 7:19 pmI'm sure the offset is slightly different on the front hub between the E46 and the zed, you may need modified brackets, keep an eye out for thatMatt.13 wrote: ↑Thu Oct 07, 2021 7:43 am I have just ordered the below. I think they will give a small upgrade in performance and look a lot better. My front are due a rebuild anyway so i thought i would give these a try.
2nd gear sideways
- Martyn
I just test fitted the Freaky Parts kit with e92 M3 discs on my Z4M, the dust shield will need to go, and it looks like the disc will be very close to the lower wishbone. I ran out of time so I’ve not checked to see if there will be enough clearance once the dust shield is removed though.
- A4DD55F2-97FA-4FC8-A7E0-825C22C77048.jpeg (169.6 KiB) Viewed 781 times
Thanks martyn . I will be using the standard disc. Let me know how you get on . They look good
2nd gear sideways
- Martyn
No dice with the e92 M3 discs unfortunately
Bummer . I guess they are quite abit thicker than stock
2nd gear sideways
