Myth or truth? Big engines question
- ronk
Not quite so often these days tho!
The original question and it’s answer is more moderated by the advances in technology rather than size.
For example a S54 engine in a M Zed has a cast iron block and no complex heat management systems.
In contrast a B58 engine has an alloy block, complex heat management, insulation on the engine etc etc
A generalisation is that you should ideally only operate an engine where you can reach the nominal operating oil temperature plus a period of time to burn off the pollutants that accumulating the oil prior to reaching normal oil temperature.
Therefore the engine when shutdown will have its moisture driven out of both the oil and its actual engine.
So a S54 may require say 25-50 miles at least to achieve that status..a B58 may require say 10-30 miles.
To come back to the point a B58 may do a lot better than an old iron block 2 litre unit
Spending time with a 35i, previous convictions: Fiat 20V Turbo Coupe, TVR Chimera, Jaguar XKR, Porsche 997 C4S
- Smartbear
What’s your take on two modern units of different capacity though?The.Analyst wrote: ↑Mon Oct 04, 2021 9:08 am The original question and it’s answer is more moderated by the advances in technology rather than size.
e85 3.0si sold
Online
That seems to make logical sense to me, thanks.The.Analyst wrote: ↑Mon Oct 04, 2021 9:08 am The original question and it’s answer is more moderated by the advances in technology rather than size.
So is the consensus that it's not the size of the engine, but the efficiency of it's heat management that's more important?
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- Smartbear
What about engines with equal modern heat management but one small/one large? That’s still not really answered the original query?Pondrew wrote: ↑Mon Oct 04, 2021 1:26 pmThat seems to make logical sense to me, thanks.The.Analyst wrote: ↑Mon Oct 04, 2021 9:08 am The original question and it’s answer is more moderated by the advances in technology rather than size.
e85 3.0si sold
- buzyg
So does the size of the engine affect the efficiency of the heat management?Smartbear wrote: ↑Mon Oct 04, 2021 1:42 pmWhat about engines with equal modern heat management but one small/one large? That’s still not really answered the original query?Pondrew wrote: ↑Mon Oct 04, 2021 1:26 pmThat seems to make logical sense to me, thanks.The.Analyst wrote: ↑Mon Oct 04, 2021 9:08 am The original question and it’s answer is more moderated by the advances in technology rather than size.
A most interesting thread to read back through. Personally, engineering slightly to one side. I think most average drivers put less strain on a bigger more powerful engine, that they do a smaller capacity engine. For a whole host of reasons. Fuel economy being one.
Online
Probably. The reason for the original question, though, is I'm thinking of buying a very high performance big engined car, so don't know if this negates anything.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
