Massive thanks to enuff_zed - DISA valve replaced and vanos successfully overhauled!! Can absolutely feel the difference already!!
New Owner
- enuff_zed
New Owner
Excellent news. Glad you can feel the difference already. Still think you'll notice it get even smoother as a few miles build up.bagginsludomax wrote: ↑Tue Sep 21, 2021 7:48 pm Massive thanks to enuff_zed - DISA valve replaced and vanos successfully overhauled!! Can absolutely feel the difference already!!
Of course that's just the vanos. The Disa is merely preventing future catastrophe.
I can't take all the credit really though. When I did my first one it was Stuart (bigwinn) there on the end of the phone if I needed help.
How easy did you find it for the vanos to clear the studs?
I have to do my 2.2i in the next week or two. When I did wifey's 2.5i I was doing water pump, thermostat, belts etc at the same time, so i jacked the engine up a bit for clearance.
Would be nice if i didn't have to do that this time around.
From talking to Stuart it seems each car varies slightly, probably due to slight differences in mounting tolerances?
Now then, about those titchy wheels
New Owner
The vanos was a bit of a nightmare on the studs - The only issue was an electrical connector in the way. It did end up moving just enough for it to come off. Putting it back on was far far easier. The actual metal bulkhead in front wasn't an issue at all. There was JUST enough room. So i had no need to move the engine. I'll take the cover off and post a photo of the space in front of the vanos later on! Hopefully it'll be the same as in your 2.2!enuff_zed wrote: ↑Wed Sep 22, 2021 8:58 am How easy did you find it for the vanos to clear the studs?
I'll have to save up! When i first ding this set I'll have the motivation to take the hit! Bigger wheels means lower profile tyres too? - my experience with those on my old corsa is that i blow out the side wall of one of them every few months!! Clearly i'm rubbish at dodging pot holes! I just had to put new rear tyres on too thanks to a nail - once again i am unable to fix it cheap thanks to the run flats. The first time i haven't blown a side wall and of course, I have run flats.
- enuff_zed
New Owner
Was just a friendly wind up about the wheelsbagginsludomax wrote: ↑Wed Sep 22, 2021 11:42 amThe vanos was a bit of a nightmare on the studs - The only issue was an electrical connector in the way. It did end up moving just enough for it to come off. Putting it back on was far far easier. The actual metal bulkhead in front wasn't an issue at all. There was JUST enough room. So i had no need to move the engine. I'll take the cover off and post a photo of the space in front of the vanos later on! Hopefully it'll be the same as in your 2.2!enuff_zed wrote: ↑Wed Sep 22, 2021 8:58 am How easy did you find it for the vanos to clear the studs?
You'll find those ones are quite comfortable and of course, no point putting shiny new ones on just in time for the roads to get salted.
Don't worry about taking photos, it's no great shakes tbh, though I appreciate the offer..
Sounds like I'll easily do it without moving too much. Will be the first time I've done the job in isolation from other work.
