Felixlamb wrote: ↑Sat Oct 02, 2021 11:53 am
Hey Jamie, looking at getting some similar tips myself. Just to check, did you go for 63mm in, 76mm out?
Cheers!
Be careful... buy local not direct from China, so you can return if necessary
I measured the exhaust at 61mm, so I ordered the closest size which I thought would work, 63mm inlet, 76mm outside.
On Aliexpress I found these: various sizes available, so I did indeed order 63/76mm
- Scb8cd08550b94b26941930121152b495l.jpg (72.02 KiB) Viewed 346 times
Shipping painfully slow, but they finally arrived, and at first glance look pretty good, until........ da fuq?
- IMG_20220523_105157.jpg (221.29 KiB) Viewed 346 times
Check the measurements I thought, indeed the inlet was 63mm, BUT... the bloody things won't go on as there is an internal step in the bore.
The stupid thing is that either side of that step, the bore is 63mm or 61mm towards the outlet. Absolutely dumb design, make sure the internal bore is the same along the length of the part before you buy.
- IMG_20220523_093101.jpg (85.91 KiB) Viewed 346 times
Can't be arsed to return them, I'll redesign and reconstruct using the materials, so not a complete waste.
By the way, I was able to twist the original tips of by hand, eat an extra weetabix
